#81 |
Ok, here's my take on this issue. Maybe I can clear up a few of the misconceptions. I've run both stick combinations mentioned here in two different eliminators with great success so I'm giving information based on personal experience, not heresay or theory. I'm not "current" on the newest rules and technology, both of which have probably evolved but the complaints, issues and applications I see here are still the same.
G&G originally built the first low drag, "all roller bearing" nash 5 speed transmission for me with a custom made second gear ratio. It was the bleeding edge of development so you see I am partial to technological advancements. Back then, clutchless 4 and 5 speeds were available but not legal in SS. So, if you are wondering whether or not they are available now, the answer is yes, they will build anything you want in a standard or custom conifguration if you are willing to pay for it. The advantage to using a 5 speed with 4 gears in Super Stock is that you can underdrive 4th and not be locked into a 1 to 1 high gear in order to achieve the optimal gearing for your combo, an option not available in a 4 speed box. I ran this setup in a 283 car with an underdriven high gear as will as a SS/A and B stick shift car with delay box, electric button release and pneumatically operated clutch pedal. I was also one of the first handful of (5 or 6) SS racers to use the 4 speed Jerico transmission. At the time, it was not available (nor could I run it in SS) as a clutchless unit. I showed the gearset to Dave Danish at the US Nationals tear down barn and he agreed that with the backcut on the faceplates, it would be next to impossible to make a clutchless gear change without a power interuption, thereby negating any benefit of a clutchless gear change with a "standard" transmission. Over the years I've had clutch levers break causing the clutch to drag on the gearchange and I was lucky to successfully get the car into the next gear. So I'd be very skeptical of anyone who tells you that they are making gear changes in a legal Super Stock stick car without using the clutch. Even if they had modified the trans to shift that way, it would not be reliable enough or consistent enough to go the 5 or 6 rounds necessary to win a National Event. Bottom line: If you are gonna present yourself as a Stock or Super Stock stick shift driver, learn to drive. And I'd tell the automatic guys the same thing. NO tranny brakes, NO delay boxes, NO lock up converters. Now, clutchless gearbox. (Jerico, G&G or Liberty) Definately faster, but like most changes in racing, the overall gain is not made with a single change. The biggest gain with this combo is in the bellhousing. If you're after every hundredth, a Racepak or similar computer is a must and you are gonna have to learn the clutch and chassis. In the end it will be faster, more consistent and easier on parts. And for NHRA, they won't have to worry about checking for clutchless gearboxes. As a die hard stick shift driver (and having owned and driven both combos to National event wins) I can't consciously agree with letting the automatic guys have tranny brakes, delay boxes, auto shifters or lock up converters in Super Stock without allowing the stick shift drivers the same technological benefits. It simply doesn't present a level playing field for all of the competitors. I've been against automatic transmission gagetry ever since Bernie Agaman (spelling??) introduced the first tranny brake in Super Stock in his Corvette. It was a pneumatic emergency brake drum looking contraption mounted on the output shaft of the tranny. I feel like.... if you are gonna drive a car in a race, then learn to drive. If you wanna play games with electronics and gadgets, then stay at home and race with your Wii. Cost?? Well, the cars will go faster with clutchless transmissions. They won't be as violent, they'll be safer, and they'll be easier to drive. As for the guys already in Super Stock, short term costs will go up but I believe you'll be getting your money's worth in terms of performance and adaptability and you can sell all of your old stuff to the Stocker crowd. The increased cost puts entry level Super Stock racing out of reach for more new competitors. Personally, I'd like to see em take away all of the "gadgets" being debated in this thread so we can see how many real drivers there are out there. I think the fans would go for it too. After all, isn't that how this "sport" got started in the first place?? |
#82 |
Liked 319 Times in 108 Posts
Pvt. Parts,
I can't speak for anyone else, but I have drove my brothers car with jerico just plain jerico nothing changed at all I shifted it clutchless he drove it that way every pass for 4 years first year he used the clutch. He was bracket racing every weekend and ran a few pro ams but anyway he shifted without clutch 4 years probaly 1000+ passes rebuilt trans after 5 years racing replaced 2 faceplates/sliders had cracked shifting fork,the new one came in magged it and it was cracked as bad as used one also had small crack in low gear,we can't say after getting new fork with crack that fork and gear were'nt cracked when the trans was new. So what I'm saying they are being shifted without clutch and ran that way for hundreds of passes without breakage. Mike Taylor3601 |
#83 |
What car? What Class? A Super Stock car??
Jerico may have taken some of the back cut out of the faceplates and they could be a newer design. I broke second gear in one of the first ones they build and I've always shifted a Super Stock car with the clutch. In fact, under power you couldln't pull it out of gear with both hands if you wanted to. |
#84 |
Liked 22 Times in 22 Posts
i agree with pvt parts. the g-forces we have that are clutch assisted could never be pulled out without some ignition interuption. i know people say they drive them without the clutch, but not the ones we own.
don,t have one |
#85 |
Well, i dug some videos out of my library the other night and was watching some footage from national events from about 10-12 years ago and it was sure nice listening to all the stick shift drivers in Stock/Super Stock using the clutch as they went down the track-those were the days...
Sean Fischer ![]() |
#86 |
abc
Jeff Lee 7494 D/S '70 AMX Last edited by Jeff Lee; 01-05-2010 at 01:17 AM. |
#87 | |
Jeff Lee 7494 D/S '70 AMX |
#88 |
i am no clutch genius, as this statement will confirm, but if a clutch is so loose you can pull a trans out of gear under what would normally be impossible conditions, how can the car be quicker if the clutch cant even put a normal load on the druvetrain. looks like you need something more than a clutch adjustment, looks like you might need more power.
don,t have one |
#89 | |
#90 |
let me restate my question, if a motor pulls good from 8200 to 9900, and you lock it down hard in all 5 gears, and you see it never dropped below 8400, and did not blow the tires off, what benefit is slipping the clutch?
don,t have one |
