Old 11-20-2009, 03:38 PM   #1
Casey Miles
Liked 508 Times in 92 Posts
Default Re: Schubek Lifters
I had Schubeck and I'm not say that they aren't a good product,but I still wouldn't take a chance on anything like them any longer. If you even chip one, get ready to take the motor out , buy new pistons and also reboring the block. Never mind all the other small parts you have to replace. (oil pump, camshaft, bearings, and on and on.)
Casey Miles
248H
Old 11-20-2009, 04:03 PM   #2
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Thumbs down Re: Schubek Lifters
Casey Miles
248H
I know its beating a dead horse but if the valve spring rule had never been changed to any pressure the lifter problem and cost would not be there. NHRA should have just gone ot a standard pressure across the board for all models and brands of engines that would allow equal performance for everyone without the expense of using something like a Shubeck type lifter...... something around 150 lbs on the seat and 350 lbs open and these hi RPM shift points would go away (more savings) . Oh well then they would have to check valve spring pressures at tear down again. To much work I guess.
Old 11-20-2009, 04:56 PM   #3
Yep ,Terry. Then you wouldn't need weldments added to the pushrod cup on OEM type rockers, only on certain brands.
Old 11-20-2009, 05:10 PM   #4
X-TECH MAN
Banned
Talking Re: Schubek Lifters
So what we have is another Super Stock class with a tire size limit and spec cam lift. The heads are "almost" the same....lol.
Old 11-20-2009, 06:00 PM   #5
bob shirley
i have had 4 of them break , stay away from them
bob shirley is offline   Reply With Quote
Old 11-20-2009, 08:55 PM   #6
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Question Re: Schubek Lifters
4 From which manufacturer, Schubeck or Smith?
Old 11-21-2009, 07:42 AM   #7
terry1
Liked 24 Times in 13 Posts
Thumbs up Re: Schubek Lifters
I've been running/using my Schubek lifters for quite a few years now,never a problem.
terry1 is offline   Reply With Quote
Old 11-21-2009, 08:24 PM   #8
Glenn Briglio
There were many problems with the Schubeck lifters. I've sold about 50 sets of the Smith lifters with zero failures to date. I would like to hear of any problems with the Smith lifters.
Old 11-21-2009, 08:34 PM   #9
Tool steel lifters are sold by Ferrea, Performance Research Incorporated, and Precision Performance Products.
