Liked 138 Times in 51 Posts
I prefer the aluminum versions. They would seem to be much more durable than plastic and I've seen several older plastic ones that had deformed. Summit has some aluminum 4 & 5 gallon sizes that may be worth considering. I have an aluminum 10 gal. now but will eventually go to a 5 gal.
http://www.summitracing.com/parts/SUM-293205/ http://www.summitracing.com/parts/SUM-293204/
LOCOMOTION Racing |
Liked 26 Times in 13 Posts
I have a Summit 5 gal aluminum cell that I put in about 5 yrs ago when they made the change to allow cells in stockers. I had a MAJOR issue with the Summit cell. Whatever sealant was used between the filler and the tank was crap. It was not properly resistant to gasoline and began disintegrating. My tank was full of chunks of sealant which caused continual problems with pumps and filters. It would clog an in-line Earl's filter in one run. That was a long time ago and hopefully Summit has corrected the problem, but it is something to watch out for.
Bill Harris ex 2172 STK ex 2272 S/S |
Have summit cell bought alluminum this spring no problems
Can you legally take the foam out of the cell?? Most of our problems seem to stem from the foam degrading and getting into everything!
Liked 70 Times in 29 Posts
you don't need foam
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
