Old 05-07-2009, 11:38 AM   #1
buzzinhalfdozen
Liked 11 Times in 8 Posts
Default Re: 351 w RPM
Cranks OK to 7000-7500, biggest problem is keeping rod bearing in one. Sorta long stroke narrow big Dia. bearing, bore big end doesn't like to stay round. This is from my personal exp. Joe
Joe Buchanan SS/BX 3117
Old 05-07-2009, 01:15 PM   #2
Chris1529
Liked 70 Times in 29 Posts
What kind of balance do you have on it?
I'd say to keep it under 7000 if you want it to live.
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 05-07-2009, 06:33 PM   #3
Bub Whitaker
Stock rod won't work...RPM sensitive... the piston weight, no mater what it is, will make the rod elongate at hi rpm and pinch the bearings at the parting line and starve it for oil and then ... ca boom. The stock rod is marginal to 6000. You really need after market rod that has more big end integrity...
Bub Whitaker
Bub Whitaker is offline   Reply With Quote
Old 05-07-2009, 09:38 PM   #4
RPM5595
RPM5595's Avatar
Liked 32 Times in 14 Posts
For what it's worth, I flat will not build a 351W with stock rods anymore. Every time In the past I let a customer talk me into it for a "low buck" circle track engine the rods have broken. As was stated before if you keep it below 6000 rpm it may last, awhile. A really good "low dollar" rod for these engines is a Eagle "SIR" series with ARP bolts. MUCH better rod than the factory piece. Hope this helps.
Jay
Jay Roeder
facebook.com/racefuelsales
Former N/SA , Soon to be SS/AS, Renegade Race Fuel dealer
RPM5595 is offline   Reply With Quote
Old 05-15-2009, 06:05 AM   #5
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
I've got question if 351W rods marginal @6000 how can 351Cs live at 7000-8000 with shorter version of same rod?I've seen plenty of them ran 7000-8000 range and live.What did 4BBL 351C stock-super stock
combos run before aftermarket rods were legal,I know they did'nt stay 6000 and below if you try to run
4BBL 351C without going over 6000 your're wasting your time.
By all means I'd run aftermarket rod since you can buy eagle SIR style etc. just few dollars more than prepping stock rod w/bolts,float pins,if you bushing them you'll spend more than aftermarket I-beam cost.
Mike Taylor3601
Old 05-15-2009, 07:13 AM   #6
BlueOval Ralph
Banned
It was not the same rod just shorter! 351-c has a different journal dia (smaller) that 351-W
Alot of guy's used Boss 351 which had a magged rod, it was also a forging and special bolts.
Mike Taylor3601
BlueOval Ralph is offline   Reply With Quote
Old 05-15-2009, 05:32 PM   #7
Mike Taylor 3601
rod throw on crank is same size 351W-351C-351/400M but 351C/M 400M rod housing bore is ten thousands larger than 351W. So I guess 351 boss rod would be about like Chevy ''pink'' rod?
I've always liked 4 bbl 351C could have something to do with me loving RPM.
Mike Taylor 3601
