Old 06-18-2007, 01:12 AM   #1
Aubrey N Bruneau
Aubrey N Bruneau's Avatar
Liked 7 Times in 3 Posts
Send a message via Yahoo to Aubrey N Bruneau
Default Stocker Slicks... Screws ? Tubes ?
Been a while, guys...
I'm just in the process of FINALLY reassembling my car...
using ALL the proper parts that I was told to use[:-whoo2-:]
I have a new set of 15 X 10 American Racing Trackstars, with new M/T stick compound 29.5 X 9's.
My previous experience showed me that my heavy car likes to have around 14-15 pounds in the tires ( that was a 9 tire on an 8 rim ).
I'm told that the slghtly wider wheel allows ( requires ) more tire pressure in order to keep it flat. The fringe benefit being less rolling resistance... better speed.
Ok.... I bought it[:-stong-:]
My questions are...
If I'm going to end up at 15-16 pounds,
Do I need screws ?
Can I run them tubeless ? ( they've been mounted, with 14 pounds in them for the past 3 months... never lost a pound ).
Aubrey
1962 Chevy Belair sport coupe 409HP 409 NHRA DIV 6 now C/Stock IHRA E/Stock #6409
1959 GMC 9380 1 Ton dually, 482 CID 409 / W 5th wheel car hauler
Aubrey N Bruneau 6409 C/S
62 BelAir sport coupe, 409 HP 409
Aubrey N Bruneau is offline   Reply With Quote
Old 06-18-2007, 06:44 AM   #2
Myron Piatek
Liked 138 Times in 51 Posts
Default
If you stay with tubes, you MUST run screws otherwise a little movement will rip the stem out. But I've seem most run without, which saves weight. The tire will move a bit, especially during the first few passes. I rotate them side-to-side, mainly for wear.
It seems most racers use 9" slicks on a 10" rim. But I've heard of pressures anywhere from 14 to 26 lbs with no pattern that I've noticed relative to weight. I ran 22lbs in bias ply tires and now 20 in radials weighing 3,530+.
Locomotion Racing
http://www.geocities.com/locomotionracing
LOCOMOTION Racing
Old 06-18-2007, 09:35 PM   #3
Aubrey N Bruneau
Default
Thanks Myron...
Guess I'll just keep an eye on them. Being able to run more pressure than I thought makes me happy too. I like the high speed stability.
Trying get the car ready for IHRA Rocky Mountain Nationals in Edmonton.
Aubrey
Old 06-19-2007, 07:25 AM   #4
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Default
If you go without tubes on bias ply slicks. Coat the inside of the tire (sidewalls) with a household liquid dish soap before mounting. When you mount, clean the tire, and rim beads with brake clean, and don't lube the beads.
Or take the easy way (like I did) and run Hoosier radials. ;-)
Old 06-19-2007, 08:32 AM   #5
Bill Belden
Bill Belden's Avatar
Default
Using screws is a personal preference, some do some don't, I have always used them. I drill & tap the rim for 1/4-20 cap screws that are sharpened to the right length, I also drill into the tire bead so the screw doesn't push the tire away from the rim. As stated above, soap the inside of the tire. 15lbs seems alot for a stick car I would start with 12 or 13 lbs, I run 10 to 11 depending on the track. Also, radials don't work on stick cars.
1100 I/S
Bill Belden
Retired Stock Eliminator
[emailSTK1100@comcast.net[/email]
Bill Belden is offline   Reply With Quote
Old 06-20-2007, 12:02 AM   #6
ss wannabee
Liked 7 Times in 7 Posts
Default
Aubrey, how's the rear end holding up in the car? You still have the stock 10-bolt or did you upgrade?
ss wannabee is offline   Reply With Quote
Old 06-20-2007, 12:32 AM   #7
Aubrey N Bruneau
Default
I'd never change, Wannabee[:-sunglasses-:]
This upgrade kit that I designed, does the job, doesn't waste horsepower... and is WAY easier to do gear changes than a 12 bolt.
In the morning, I'm heading to see my machinist to pick up my rear end housing and the new brackets that I designed to install the Wilwood disc brakes.
I should post a picture of the setup before I install it. Likely a one-in-the-world[:-lookhappy-:]
Aubrey
Old 06-20-2007, 03:18 AM   #8
LNorton
LNorton's Avatar
Liked 4 Times in 2 Posts
Default
I sure hope thats an 8.5'' 10 bolt and not the 7.5'' weakling!
Lee Norton
<u>Slowtime Motorsports</u>
I/PS '02 Firebird 231 V6
Lee Norton - N229 STK
IHRA H/FIA - NHRA O/SA
RacerTees.com
LNorton is offline   Reply With Quote
Old 06-20-2007, 11:05 AM   #9
Aubrey N Bruneau
Default
Lee... a disco rear end ?
I don't think so[:-good-:][:-laughing-:]
Original 1962 Chevrolet/CDN Pontiac:
[image]http://www.bruneauperformance.ca/55-64spoolrearrear.jpg[/image]
[image]http://www.bruneauperformance.ca/aubreymay22003/moseraxles.jpg[/image]
[image]http://www.bruneauperformance.ca/pics/050401-6.jpg[/image]
Aubrey
