Old 06-03-2025, 08:35 PM   #1
Lyn Smith
Liked 1,001 Times in 203 Posts
Default G body manual steering box
Working on a 78 G body car. What is the best, and most economical way to change it to manual steering?
Old 06-03-2025, 09:14 PM   #2
Jeff Stout
Liked 708 Times in 285 Posts
Default Re: G body manual steering box
I did the standard rebuilt Vega box. Speedway has a box now. S10 is just a little bigger and safer to use then the Vega due to weight. I've had mine for about 12 years.
Jeff Stout is online now   Reply With Quote
Old 06-03-2025, 10:10 PM   #3
Bob Shaw
Liked 323 Times in 63 Posts
I used S10 boxes on my El Camino.Regal,Monte Carlo, and Seville. No modification needed.
Bob Shaw V/SA 515
Bob Shaw is online now   Reply With Quote
Old 06-04-2025, 11:57 AM   #4
Ken MacNicol
Ken MacNicol's Avatar
Liked 26 Times in 12 Posts
S 10
Ken MacNicol is offline   Reply With Quote
Old 06-04-2025, 12:33 PM   #5
Lyn Smith
I see that Speedway has one the call the "drag racing conversion box" Do you need to get the one with the pitman arm,or will the stock pitman arm work? Thanks for the info.
Old 06-04-2025, 06:57 PM   #6
Jeff Stout
I believe it's same spline for stock arm. They also have straight arm or I think deep bent arm.
Old 06-05-2025, 07:54 PM   #7
CamCam
Liked 2 Times in 2 Posts
will the s-10 box work on a 67 Camaro?
CamCam is offline   Reply With Quote
Old 06-05-2025, 09:30 PM   #8
Yes and no...
The frame bolt pattern hasn't changed in decade in that series.
The small pitman arm pattern (non-power) is still the same .
Where you might find trouble is in the steering shaft.
S10s are metric vehicles.
Old 06-05-2025, 10:58 PM   #9
