#11 |
Liked 705 Times in 204 Posts
I think I’m good, I have two 50lb bars bolted across the trunk through the frame with two 1/2” grade 8 bolts each. I just received a new Cal-Trac weight box and it’s bolted to the frame with two 1/2” grade 8 bolts also. For the Cal-Trac box I have 45lbs of shot in 10 removable bags. That should get me enough adjustable weight for different track scales.
Mike 7570 A/SA |
#12 |
Guest
Posts: n/a
See you there, bring shorts?.hot hot!
