#11 |
Liked 805 Times in 245 Posts
#12 |
Liked 869 Times in 165 Posts
Depends on whether you call it a Ford or a Mercury 302. If run as a ford, it gets the 450cfm version of the motorcraft 4300 spread bore, air valve secondary carb. If called a Mercury, you are allowed to run a 600cfm 4150 holley.
1189 F/SA Defunzalo Racing Enterprises |
#13 |
Liked 30 Times in 11 Posts
Why is that and how is that? So I have the original 70 block and matching heads. So hypothetically even though it’s from a ford mustang and I run it in my mustang in GT/QA or PA and say it’s a “mercury” engine I could run a 4150? Who checks this by the way? Forgive me for all the questions I’m new!
#14 | |
#15 | |
#16 | |
#17 | |
Liked 1,030 Times in 283 Posts
Yes, you could use the piston that fits the 68 302 combo ( 4 valve reliefs), the 68 4V heads ( C80E-F) or the aluminum replacement head, which is the better head, and more cost effective. And as a Mercury that combo takes the Holley 600cfm 4150 carb. The 390, 428, 351c, even 351w are good combos to research also. I dont think the 2bbl 302 is good for Super Stock, Matt Hawk has played with the 302 2bbl and the carb is just too small for the hp rating.
Duane Hoven 1342 SS/GT |
#18 |
Liked 783 Times in 195 Posts
Mixing engine components does not make a hybrid. Using an engine by the same manufacturer that was not offered in your make-body is a hybrid.
#19 |
Gotcha so if I run a 390 combo I could run in GT since the 390 wasn’t offered in the 70 mustang? What about a 68 302 then? I couldn’t run it in GT since the 302 was offered in the 70 mustang?
#20 |
Liked 975 Times in 311 Posts
Different year engine combo can run in GT.
