Old 10-24-2023, 04:42 PM   #111
L.Fite
Liked 498 Times in 244 Posts
Default Re: Flat tappet lifter failure
Originally Posted by Terry Cain View Post
Gotta ask yourself WHY did OEM decide to go to rollers if flats are cheaper to make?
My guess is the change in oil chemistry...
But there is supposed to be remedies for that... (additives)...
So... that begs the question, what is the REAL REASON for the failures?
Self inflicted... (spring pressure)...?
Crappy material/ QC...?
Or some yet unknown quantity...
Inquiring minds would like to know...
L.Fite is offline   Reply With Quote
Old 10-24-2023, 10:08 PM   #112
Rory McNeil
Liked 1,108 Times in 304 Posts
Well, I am certainly not privy to what the OEs were thinking in the mid 80s, but my guess would be for a fractional improvement in CAFE gas mileage, along with thin piston rings, EFI, low drag, thin engine oils, overdrive transmissions, attention to aerodynamics, serpentine belt arrangements lightweight items , like aluminum blocks and heads, plastic valve covers, intake plenums, aluminum master cylinder and calipers, plastic and aluminum body panels, aluminum radiators and heater cores, smaller displacement engines, cylinder deactivation systems, electric cooling fans, roller rocker arms, aluminum driveshafts, etc.
Hmmm, almost makes you want to built a later model car to enjoy all those benefits, isn`t it!
NHRA 6390 STK
M/S 85 Mustang
Old 10-25-2023, 04:43 PM   #113
65signet
Liked 49 Times in 22 Posts
Cummings went to roller lifters in the last few years, and they have had a lot of problems with lifter failure, and i heard its because of the oil, to get away from the high zinc oil.
Steven Barnes
Stock 704 N/SA
65signet is offline   Reply With Quote
Old 10-27-2023, 02:13 PM   #114
Jim Cimarolli
Liked 166 Times in 46 Posts
Anybody ever tried using the old GM solid lifter part #5231585?
They are obsolete now, but they have a side orfice with a hardened puck on the face.
Just wondering what kind of spring pressure they would take.
Jim Cimarolli
Jim Cimarolli is offline   Reply With Quote
Old 10-29-2023, 01:33 PM   #115
Liked 1,912 Times in 429 Posts
Just FYI, I saw a lifter exactly like the one in the OP, during an online seminar. The diagnosis was EXCESSIVE amounts of ZDDP in the oil. Apparently, people are playing "chemist" with oils, without knowing what they're doing. And, of course, there's always those who think, "if a little is good, more is better, and too much is just right". Doesn't really work with additive packages in motor oil. Once you exceed a certain concentrations, additives such as ZDDP and moly disulfide are no long additives, but rather pollutants and contaminants. They cause damage, fall out of suspension (ever seen a 1/4" plus of gray mud in the bottom of your oil pan?) and clog oil filters.
It should be noted that, over the years, there have been multiple incidences of oil additive packages being incompatible with certain components, a prime example is that several years back, the Joe Gibbs oils were causing a specific DLC coating to fail in the NASCAR Cup series engines. The DLC flaked off in just a few laps.
Never been a huge fan of DLC to begin with, it is a very "picky" thing. It doesn't like certain materials (it cannot be used against cast iron), it doesn't like certain processes, the various versions are NOT all the same, and it doesn't like certain oils or additive packages.
I have not tried it personally, but many are saying "Oil Extreme" is a good additive, used correctly. However, as with anything else, it is NOT going to be compatible with every oil.
Old 10-29-2023, 04:40 PM   #116
Doug Hoven
Liked 869 Times in 165 Posts
I’ve also read about issues relating to ring seal if one adds too much zinc to their oil.
1189 F/SA
Defunzalo Racing Enterprises
Doug Hoven is online now   Reply With Quote
Old 10-29-2023, 05:58 PM   #117
L.Fite
So...
Does someone make an oil with the proper additives package?
Looking for that "Goldilocks" zone...
Not too much...
Not too little...
But JUuuST RIGHT!
Old 10-29-2023, 09:00 PM   #118
Doug Hoven
Originally Posted by L.Fite View Post
So...
Not too much...
Not too little...
But JUuuST RIGHT!
I'm sure there are quite a few good choices on the market. Personally, I've had good luck with Driven oil in my engine so far. I used their break-in oil, br-30, and their semisynthetic racing oil, gp-1. Not super pricy, and seems to do a good job.
1189 F/SA
Old 10-29-2023, 10:56 PM   #119
So...
Not too much...
Not too little...
But JUuuST RIGHT!
One person you might talk to is Lake Speed Jr. He works at Total Seal, he's a tribologist.
I have had good success with Royal Purple. Others speak highly of Amsoil, which is an oil that David Vizard says works well with Oil Extreme. As Doug said, some have had good luck with the Driven products. I have also used both Lucas and Brad Penn successfully.
Old 10-30-2023, 09:40 AM   #120
Darcy Clarke
Liked 564 Times in 38 Posts
I have used Renegade race oil 5/20 and 10/30 it only comes in semi-synthetic, I have used it for over 10 years with great results.
Darcy Clarke
6254
A/SA SS/EA
Darcy Clarke is online now   Reply With Quote
