#31 | |
Liked 231 Times in 107 Posts
#32 |
Liked 734 Times in 385 Posts
OK the spring pressure needed is a result of lobe profile (yes there are also some other factors). Do all brands have this same problem to the same degree, or is it more a function of lifter diameter? The larger the lifter diameter the greater the max velocity the lobe profile can have. If this is the case then MoPars would have less problems than GM with Ford in the middle.
Stan |
#33 | |
Liked 780 Times in 194 Posts
Doesn't that all get worked out in AHFS and HP factors? That is the assumption with all rules changes that affect engine performance. The main reason they don't check valve spring any longer is that it takes too long, the expense of the tech staff, the risk of being sued, and the expense of equipment. So the racer is paying for the decision again, and it still is not "fair" for everybody.
#34 | |
AHFS doesn't work. |
#35 |
Roller cams will not solve the problem, and will not make it cheaper. It will only make it more expensive, change the failure mode, and cause more problems. It will create another R&D expense. It won't make anyone any faster, except maybe someone who has unlimited funds to invest in camshaft and valvetrain testing.Roller cams will simply cause more problems, and make nothing cheaper.
What will people cry about tearing up next? What rule change will they demand? How much will it cost? Where will it stop?
Alan Roehrich 212A G/S |
#36 | |
Liked 186 Times in 57 Posts
John Ancona 717 STK / SS |
#37 | |
Liked 7,772 Times in 1,742 Posts
I'm quite sure that Dwight and Alan are very well aware of the cost of running flat tappets vs. rollers. YOU may be better served by understanding there IS a reason as to why many like running older cars that came equipped with flat tappet cams in an Eliminator called STOCK!
#38 |
Ya know, you can just never have enough "roller cams for the masses" discussions!
Deja Vu? https://classracer.com/classforum/sh...ad.php?t=60886
#39 | |
Really? And you have how many class wins with your big block Stock Eliminator engines? Because I have more than 1-2. Oh, and I have a 9500 RPM+ 396-375 Super Stock engine as well. Maybe YOU can't make a flat tappet Stock Eliminator engine run. That does not mean the rest of us can't. There are a ton of VERY fast big block Chevy stockers out there running flat tappet cams and having zero problems. Maybe you should ask yourself why YOU can't.
#40 | |
