Old 08-15-2023, 04:31 PM   #1
jaf2021
Liked 5 Times in 5 Posts
Default Battery comparison
How does a XS D1600 or S1600 compare to regular 850-1000 amp 12-volt battery?I see the amps are a lot lower on the 16 volt but it being a 16 volt is it going to give as much cranking power than the 12 volt? Will it have to be charged anymore? I have a super stocker with no alternator. Any opinions would be greatly appreciated thanks jason
jaf2021 is offline   Reply With Quote
Old 08-15-2023, 05:04 PM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,983 Times in 597 Posts
Default Re: Battery comparison
Higher voltage means less amps needed for the same work.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 08-15-2023, 05:14 PM   #3
Steve Grady
Steve Grady's Avatar
Liked 170 Times in 55 Posts
Multiply Volts x Amps to get Watts for a comparison of output for the 12 volt vs 16 volt battery.
Div 3 Sales, Service and Tech for many manufacturers
Steve Grady is offline   Reply With Quote
Old 08-15-2023, 05:55 PM   #4
ausby
ausby's Avatar
Liked 34 Times in 18 Posts
I had 12v on my big block and would break teeth on the flexplate. switched to 16v. spins over like a stock engine would
Ausby Brewington
A231 S/G
ausby is offline   Reply With Quote
Old 08-16-2023, 08:14 AM   #5
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
I ran 2 AC Delco 1000 amp 12 volt batteries in my former super stocker for 12 years without issue, swapping them out every 4 years. I decided to swap to XS D1600 at the conclusion of the 2020 season so both my cars(other is a dragster) would have the same battery.
I have always run an alternator and wouldn't race without one. Charging is the same as a 12volt. Every electric motor spins faster...starter, water pump and fuel pump.
The only down side is 16volt batteries do not have the reserve capacity that 12volt do, they have a history of working and then not without warning and they are heavy, 47lbs.
The dragster now runs a lite weight (8 lbs.) 16v lithium battery
