Liked 19 Times in 10 Posts
Can someone enlighten me on these heads? It seems the exhaust ports are re-positioned from stock?? Exhaust flanges shortened???
Using these on a Super Stocker and they are causing some real grief. |
Liked 754 Times in 213 Posts
From the Edelbrock technical instructions:
Exhaust flange has been extended out .125” in order to provide dry exhaust bolt/stud holes. From NHRA classification, they carry a penalty (weight/ratio HP) for using those heads. https://edelbrock-instructions-v1.s3...rock/60917.pdf Last edited by Charles Stewart; 06-13-2022 at 10:31 AM. |
#3 | |
Liked 1,937 Times in 582 Posts
Mike Pearson 2485 SS |
Liked 88 Times in 43 Posts
I expect what Mike is saying is....Yes, fully prepared (ported/welded/etc.) SuperStock heads, regardless of origin, probably have had the exhaust ports relocated somewhat, and had the flanges cut down for port volume reasons. Without seeing what you're working with, I'd anticipate that exhaust flange adapters, properly matched to the port center-lines are going to be necessary.
Liked 10,731 Times in 2,233 Posts
If anyone has a set or two to sell I am very interested. Thanks
