Liked 498 Times in 244 Posts
So... what gear ratio is common on 396 or 427 combos?
From past experience I'm guessing 4.88 or 5.13? Would that be in the ballpark? How tight do those things turn? (in a stocker?) 7000? 7500? MPH 130ish? |
Liked 232 Times in 108 Posts
A lot of factors to consider. Oval or Rec port? Weight of car? HP rated and dynod? 1/4 or 1/8 racing.
Liked 358 Times in 83 Posts
What Terry said...
Liked 328 Times in 80 Posts
Tire diameter should be considered as well. Radial or bias ply will play into the equation too.
Ernie Neal SS 354 |
Liked 30 Times in 16 Posts
Back in 1992 I went 10.54 at 123 mph with a 5.13 at the Snowbird Nationals 29.5 Firestone slick crossing 7600 rpm.
Nothing burger cast crank BBC 427 600 lift flat tap, steel Merlin heads 3475 all steel Nova That was flying in 1992 home built on $10.00 bucks an hour. I'd put a 5.13 in it. I learned the easy way in 92, the first 100 ft makes you. |
Liked 128 Times in 50 Posts
Wasn't the 5.00 gear created for these combos?
Bobby Lundholm 3516 G/SA |
Liked 226 Times in 137 Posts
#9 | |
Square port stuff... A/S, B/S, etc. Looking at some of the heads up races, can't tell how hard they are running these things, just got me curious. Putting a car together and trying to decide what I want to do with it... Long way to go yet... |
Thanks.
