I'm replacing gear and roll pin on SBC, I was able to pull gear off by hand. Snug but not pressed on is this a pressed on fit to not completely rely on pin for strength ? New gear is on way so can't check new gear fit
thank you |
Liked 336 Times in 183 Posts
X2--but they should not be real sloppy either --kind of a gentle tap with a SMALL rubber mallet to help it slide on--dont BEAT IT ON--just a little harder than hitting it with your fist--some go on real easy and some are "snug" --if need be try a scotchbrite pad to "polish" the shaft --dont go ballistic here
Liked 90 Times in 52 Posts
i.ve seen some manufactures offer .492 " & .500 " id sizes gears for chevs .. check what you have
also spend a dime and put in a new roll pin and gasket too-- then check your tooth engagement depth and make sure that the distributor has not bottoming out when you tighten the bolt that is too far down
Liked 398 Times in 153 Posts
Not to mention using the correct type of gear for the cam - plain old cast iron, melonized, bronze, composite all have different cam cores they are compatible with.
Phil Molski PMR Performance S/C 1623 |
Liked 205 Times in 93 Posts
is there not a referance dot on the gear? can be installed either way?
Liked 7 Times in 6 Posts
