#11 |
Liked 57 Times in 24 Posts
#12 |
Liked 225 Times in 88 Posts
On an A/SA car c06 wont last as long as c07 , but an A car gets less tire life in general compaired to my E car , I do 2 to 3RD gear burn out count to 5 and drive out , 20psi . What rear shocks and settings and do you hit a wheelie bar like most A/SA cars ?
#13 |
Liked 431 Times in 224 Posts
I run the C07 tire at 17 psi on a 10" rim and get at least 150 passes. I don't use the line lock at all on the burnout. 1-2 and out. Car is 3600 lbs, 1.41 - 10.20.
I experimented with Goodyears for a bit but I've generally run this same combination on Hoosier radials since 1995.
S/ST 51 S/C 53 |
#14 |
Liked 977 Times in 312 Posts
You should be using more than 15 lbs air pressure
#15 |
#16 | |
A couple times I have waited too long to replace them and when these tires are done, they are DONE and will not hook at all.
S/ST 51 S/C 53 |
#17 |
My bad wrong thread
#18 |
Liked 2,360 Times in 467 Posts
Willy If you are getting close to 40 passes on a set of lightweights you have done well. You are running A/SA with a big block Chevy not only will it eat tires but it also likes the taste of money. Not sure why you put a set of lightweights on. Buy the regular ones and you will get 50 plus runs on them. BP
#19 | |
S/ST 51 S/C 53 |
