Old 01-21-2020, 10:44 AM   #11
Nick_Siebert
Liked 66 Times in 12 Posts
Default Re: Question on loosing fuel pressure going down track.
I had the exact same problem become present on my 305, Q Jet Camaro, it was a faulty pressure regulator at the carburetor.
Nick_Siebert is offline   Reply With Quote
Old 01-21-2020, 12:09 PM   #12
rod butcher
Liked 132 Times in 27 Posts
A friend had this same problem this year and found it to be a very restricted fitting from tank to pump. This was after he changed pump and regulator. It was a 90 degree fitting.
rod butcher is offline   Reply With Quote
Old 01-21-2020, 12:32 PM   #13
Ed Wright
Ed Wright's Avatar
Is this a stock fuel tank? Not a fuel Cel?
To eliminate a weak (low volume) pump, I would add 5 gallons of fuel. If that stops the pressure drop, it will usually indicate the pump pick up being uncovered due to placement in the tank.
Ed Wright 4156 SS/JA
Old 01-21-2020, 05:24 PM   #14
Jeff Stout
Liked 708 Times in 285 Posts
It is a fuel cell with about 10 gallons in it mostly to make weight. Has rear sump and exit with pump directly behind it. Im pretty sure I 45 degree or straight fitted everything. I did install a -8 inline fuel filter when I built car 35 passes ago.
Old 01-21-2020, 06:15 PM   #15
It's the G force causing the problem.
Old 01-21-2020, 07:10 PM   #16
Ed Wright
Ed Wright's Avatar
How quick does it ET? And 60’?
Old 01-21-2020, 08:57 PM   #17
Mike Pearson
Mike Pearson's Avatar
Liked 1,983 Times in 597 Posts
What side of the pump is the filter. I have never ran a filter in my fuel system
Mike Pearson 2485 SS
Old 01-22-2020, 09:17 AM   #18
Hacksaw
Liked 314 Times in 177 Posts
If you are using a fuel filter, check the Microns.
Old 01-22-2020, 10:31 AM   #19
Jeff Stout
1.88 60ft 14.50 ET.
Old 01-22-2020, 10:33 AM   #20
Jeff Stout
I have the filter mounted near the passenger door. Pump is directly behind cell
