Old 01-03-2020, 03:00 PM   #1
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
Default Oil pre-heater
I just got a couple Moroso 23991 400 watt probe type heaters and I've been told they can scorch the oil. I notice that the Stefs is a much lower wattage. Which oil/trans oil heater do you use? Thanks for your advice.
Ron Gusack is offline   Reply With Quote
Old 01-03-2020, 03:09 PM   #2
Alan Nyhus
Liked 799 Times in 236 Posts
Default Re: Oil pre-heater
For engine oil, a Kats watt magnetic heater...steel pan, of course. For the trans, a Zero Start heater with a 1/2 NPT bung welded to the trans pan. -Al
"That'll never work....."
Old 01-03-2020, 05:04 PM   #3
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Got a few of the Kats 300 watt magnetic heaters. Gonna have to get something different for the EF/S car, Aluminum pan.
Dave Noll, EF/S ,?/SA 6526
Old 01-03-2020, 06:30 PM   #4
Shadylane
Shadylane's Avatar
Liked 171 Times in 51 Posts
I’ve used the Moroso external heating pad for a couple years now. Takes about 30 minutes to heat the oil. Sticks on, they have different sizes or a model that attaches with springs.
Moroso 23996 - Moroso External Heating Pads
Kelly
Shadylane is offline   Reply With Quote
Old 01-03-2020, 06:47 PM   #5
jmantle
Liked 172 Times in 81 Posts
We put heaters in the oil pans and hydraulic tanks of heavy equipment on a regular basis, the general rule was no more than 10 watts per square inch of heating element. High wattage units made for water will cook the oil. More info here, https://www.warrenelectriccorp.com/a...rs/default.asp
Jim Mantle V/SA 6632
jmantle is offline   Reply With Quote
Old 01-03-2020, 08:56 PM   #6
bykr
Liked 167 Times in 81 Posts
I siliconed the Moroso heater to the bottom of my aluminum pan worked great, but would leave it on for only about 30-45 minutes.
Tim Schmackpfeffer 762 SS
bykr is offline   Reply With Quote
Old 01-03-2020, 11:31 PM   #7
Ron Gusack
Ron Gusack's Avatar
Thanks for that information Jim. If my math is correct, this heater has 63.69 watts per sq. in. I guess I'll send both of them back. The heating probe is 4" long and .5" in diameter with 400 watts.
I tried a stick on pad but when I saw smoke coming out of the diaper after a few minutes, I took it off.
Old 01-03-2020, 11:41 PM   #8
Ron Gusack
Ron Gusack's Avatar
I'll check these out Alan, thanks
Old 01-04-2020, 01:48 AM   #9
FED 387
Liked 333 Times in 180 Posts
Definitely look at the Stef's heaters ---either the pad or the in the pan style---the in the pan style is for use in OILS --the Moroso style heater is for WATER---Go to Stef's website read about their products--- other suppliers may make a similar product but the Stef's style will not scorch the oil because of its design---the only difference between using it in a steel or aluminum pan is the bung that you weld into the pan steel for a steel pan and aluminum for an aluminum pan-- FED 387
Old 01-04-2020, 11:18 AM   #10
Eman
Liked 133 Times in 76 Posts
Some have used a plumbers pad, available at Lowes, to protect their diaper. Pad has to be sealed around the edhes to the pan if it peels it will burn itself up.
Eman is online now   Reply With Quote
