Old 11-17-2019, 10:27 PM   #1
littlemanjoe
Liked 75 Times in 28 Posts
Default Stock Eliminator camshaft question
Tool steel or Cast steel for stock eliminator camshaft?
littlemanjoe is offline   Reply With Quote
Old 11-19-2019, 09:53 PM   #2
SDT1DYI
Liked 453 Times in 146 Posts
Default Re: Stock Eliminator camshaft question
One thought , depending on required spring pressures for your motor, start with a Cast iron nitrided cam core. Figure out what cam profile is best ( generally after 3-4 cam swaps at 200.00 ea) and then go to the expense of a tool steel cam core. With 200lbs on the seat, a C.I. cam that's broken on correctly, should be ok for 80-100 runs before it should be removed and inspected with the lifters. PPPC will resurface a set of tool steel lifters for 125.00.
Good Luck either way you go.
Steve Teeter. STK/SS. 6380/6283
SDT1DYI is offline   Reply With Quote
Old 11-20-2019, 09:30 AM   #3
Terry Cain
Terry Cain's Avatar
Liked 230 Times in 106 Posts
Contact info for PPPC, please? TIA
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 11-20-2019, 12:39 PM   #4
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
www.pppcenter.com
