#31 |
Liked 229 Times in 99 Posts
A friend of mine had one let go. Went right by the flex plate shield, through the dash and took out the windshield.
Floyd Staggs 787 SST |
#32 | |
Liked 2,750 Times in 971 Posts
I was always told not to by very reliable sources although I had always wanted to to kill the motor after crossing the finish line for all the right reasons and at the time it would have been easy because we were still using the push button shifter in the Max Wedge car. |
#33 |
Liked 320 Times in 102 Posts
Shutting down the engine at speed with an automatic means that there is no pressurized internal transmission lubrication...
The last time I shut off an engine in the lights we were running D/G at Half Moon Bay in 1968... Just sayin'
#34 |
Liked 880 Times in 311 Posts
My Slayed Valve odd fire V-6 will shred Jesel belts if you kill it at the finish line. If I put it in clean neutral and let it idle, high idle, the belts last a long time. Guess how I found this out??
Adger Smith (Former SS) |
#35 |
I’ve always shut mine off at the finish line. Super stock modified motor turning 10,200.
Jeremy Mudd |
#36 |
I always put it in neutral and shut off my small block Stockers
at finish if they are turning close to or over 7,500. The Stockers that are still in the high 6000s....I do not worry about it.
#37 | |
I would have know this. |
#38 |
Liked 263 Times in 68 Posts
Never had a problem putting trans in neutral after the finish line.
John Dinkel 3295 STK |
#39 | |
All my Protrans stuff always looks great when Dave goes thru it!
#40 |
Liked 10,838 Times in 2,253 Posts
Using a clean neutral helps keep the big end of the rods round longer.
