#11 | |
Liked 53 Times in 38 Posts
#12 | |
Liked 21 Times in 13 Posts
I just bought a new strange MC. Their recommendation is with 4 wheel disks, use a 1.125 bore and with 2 wheel disk, 2 wheel drum to use a 1.032 bore. I can say, without even bleeding the lines the pedal feels good, better than the mopar aluminum one I had on
Brian Carpenter Stock 1358 |
#13 |
Liked 10,867 Times in 2,255 Posts
Dont forget to look at break pedal ratio when changing from power to manual.
#14 | |
Liked 133 Times in 76 Posts
#15 | |
Mike |
#16 |
Not sure what the differences are. the mopar one might have had an issue, Although one thing I did different going from one to the other is that I now have the rear brakes plumbed to the rear port on the MC. I read that the rear port provides more fluid flow, and I'm trying to make sure I have good holding power on the rear when staging. we'll see.
#17 |
Hey Mike, pretty much done here. Front alignment next week. engine has been on the dyno and I've driven it around the neighborhood, which I very much enjoyed, not sure about my neighbors !
#18 | |
If you want more holding power in the rear increase the size of the wheel cyls or calipers. |
#19 | |
I've got strange discs in front and back with their recommended MC. I'll wait and see how that works.
#20 | |
Mike |
