Old 01-27-2018, 10:42 AM   #1
Steve Starnes
Default Tires may hit fender
I put 275-60 15 nitto drag radials on my Mustang Fox Body. There is about 1.5" of clearance around the tire but if the body came down 2" under launch it will hit the tires. I didn't want to flare the fenders if I don't have too. What can I do to insure the body doesn't squat in the rear?
Steve Starnes is offline   Reply With Quote
Old 01-27-2018, 12:03 PM   #2
Ed Wright
Ed Wright's Avatar
Default Re: Tires may hit fender
If your chassis works correctly, the car will not drop down over the rear end/tires.
That unloads the tires.
Ed Wright 4156 SS/JA
Old 01-27-2018, 12:14 PM   #3
fordteacherguy
Liked 160 Times in 51 Posts
Baseline Suspension, Team Z and others all make bolt in rear suspension kits that can adjust anti-squat or you can always throw in the trusty airbag in the RR for a inexpensive fix.
Brian Thompson
NHRA Stock / Super Stock
Class P/SA 6665 SS/MA 6665
fordteacherguy is offline   Reply With Quote
Old 01-27-2018, 12:20 PM   #4
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Steve,
You could roll the inner fender lip to give more clearance. What is the application, and what rear suspension modifications do you have?
I am with Ed!! If it is setup correctly it will separate, and not drop down on the tire. I run a system like the baseline suspension that Brian listed. It is an adjustable upper control arm similar to a 4 link. It allows pinion angle adjustment along with IC adjustment.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Sean Marconette is online now   Reply With Quote
Old 01-27-2018, 08:02 PM   #5
Steve Starnes
The current suspension is stock. We just put new gears, axles and differential.
