Liked 3 Times in 2 Posts
I’ve got a set of Caltracs on my ‘70 Nova with Landrum monoleafs. The right rear spring is bent, I’m guessing from the force applied by the Caltrac bar. Is anyone running doin anything to strengthen the Landrum (extra top half for example) or just running Calvert split monos? Thanks guys.
Calvert split monos!
Joe Martens AA/Stock 3969 |
Liked 10,720 Times in 2,232 Posts
What is bent? Front or rear segment and has ride height changed? You might be able to add a half leaf.
The Landrums are a parabolic monoleaf. The front of the spring is bent. Yes it changed the ride height.
Liked 2,486 Times in 697 Posts
I have a dozen cars with John's springs and shocks.
A couple are Heavy and have over 500 runs on them in last ten years and we have not noticed any issues. We adjust them accorded to his directions and make sure that nothing is binding and everything is free moving. Perhaps the geometry on the spring you are using is not compatible....We bought a car with Mopar Superstock springs and Calvert bars and it was so bound up that it may as well been mounted solid! I have never tried them without his springs or driven them extensively on the street. His stuff is the best things we have every used on suspension......Use his Shocks/Struts and other suspension pieces as well.
John Irving 741 Stock 741 Super Stock Last edited by GTX JOHN; 02-07-2018 at 04:35 AM. |
Might be able to press it back to correct ride height, then add half leaf of same curve. I agree with John everything needs to move freely.
A four wheel scale will tell you a lot. Good luck |
Liked 162 Times in 45 Posts
I have run the Landrum springs forever with no problem and no extra leaves. If you bent a spring I would think something is bound up or way out of adjustment.
Liked 507 Times in 92 Posts
Look into a company called Flex Form, they have composite springs. About 8 lbs a side and are around $400.
