Old 12-17-2017, 05:07 PM   #21
Billy Nees
Liked 7,780 Times in 1,743 Posts
Default Re: Switch to 2bbl
I think that you would probably slow down more than .5. You can't use the big 2V on your combo and the L index is tough.
Billy Nees 1188 STK, SS
Old 12-17-2017, 07:02 PM   #22
rick winchester
Liked 207 Times in 34 Posts
At 3418lbs your car would be n/sa with a 13 flat index. 3418 -170 for driver devided by 224 hp =14.5 n/sa Rick
Rick Winchester Stk 3277
rick winchester is offline   Reply With Quote
Old 12-18-2017, 10:40 AM   #23
rboyle
rboyle's Avatar
Liked 586 Times in 162 Posts
Sorry, my mistake on the classification. Yes 3418 is 52 lbs less than my current minimum and .85 less than my current index so about a .90 difference, right?
Old 12-18-2017, 11:40 AM   #24
Mike Jones
Liked 684 Times in 289 Posts
I would expect more than a .5 drop off, if you can`t use the big (1.375) 2GC.
Only 1 L car (-.617) at 1-7 LODRS @ E-town. A few N`s, and at least one of them used to be in L.
See Billy`s post above.
Mike A114
Old 12-19-2017, 10:03 AM   #25
Coleydog
Liked 53 Times in 38 Posts
I'm totally confused now, I thought the drivers weight was added to the shipping weight? The shipping weight was divided by the HP
Old 12-19-2017, 01:54 PM   #26
Rich said his car weighed 3418. One would assume that's with the driver weight added. So, the 170 needs to be removed to find the natural factor for the car. Then you would adjust to the lightest possible weight for that class. Then add the the driver weight for the total weight with the 2 bbl .combo.
Old 12-29-2017, 01:27 AM   #27
goinbroke2
Liked 394 Times in 154 Posts
I’m still wrapping my head around the 350cfm for the 305 2bbl and 500cfm for the 350 2bbl.
302 is 287cfm and 351 is 356cfm. Only wish Ford had 350cfm on the 302.
Old 12-29-2017, 08:29 AM   #28
Billy Nees
305 uses "medium sized" 2bbl, about 325 CFM.
69-70 350s use "really big" 2bbl, about 400 CFM.
All other 350s use "big" 2bbl at about 350 CFM.
FFFFord put 350 CFM carb on 82 manual trans Mustang GTs only.
