Old 06-03-2017, 09:07 AM   #1
dragracerray
dragracerray's Avatar
Liked 210 Times in 91 Posts
Default Stock rules 2 Step, 3 Step
I have trouble interpreting the rule book. It says,
IGNITION, Automatic
Two-step permitted. Two-step must be foot-activated through brake pedal, clutch pedal, or pressure switch. Hand release prohibited. All wiring associated with the ignition system must be fully visible, labeled, and traceable. See General Regulation
Does this mean a 2-Step is legal and a 3-Step is not?
thanks in advance for the advice! Ray
dragracerray is offline   Reply With Quote
Old 06-03-2017, 10:07 AM   #2
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
Default Re: Stock rules 2 Step, 3 Step
As I interpret the rules, Ray, you can have 3 rpm-limiters -
  1. Launch limit - set-up as you described from the rulebook
  2. Low side limit - which I use to control burn-out rpm
  3. High side limit - for catastrophic protection.
If you do a thread search you'll find a lot of information on how to set-up and wire the launch limiter, as it is the most critical of the three, at least as far as the rules are concerned.
Good luck with your project!
Lew
Lew Silverman #2070
"The Wagon Master" N/SA
Old 06-03-2017, 07:55 PM   #3
dragracerray
Thanks Lew. I have raced off and on since 1980. My first trip to Stock Eliminator later this year in Division 1. Ray
Old 06-03-2017, 10:22 PM   #4
Lew Silverman
I try to help when I can! The rulebook can be somewhat confusing at times, especially when they try to make things simpler!
Hope to see you out there soon!
Lew
Lew Silverman #2070
