#11 |
Liked 5,140 Times in 1,962 Posts
What kind of computer/ management system?
#12 |
All factory Mark. The person who does the tuning is about 2 /12hrs aways. I've been trying to avoid making that that drive just to have him plug it in his computer. But I will if I need too..
#13 | |
Anyway, more power, more stall, and vice versa.
#14 |
I'm sure he did. I've been running this trans I believe for 2 years now w/ no issues. If for some odd reason the converter checks out okay on the dyno I'll get the car back to the tuner and have him check it.
Thanks. |
#15 |
Jamie,
I notest you moved the battery to the back of the car. Check all the grounds for the pcm that they are good ! Also anything under 10 volts and crazy thing could start happening don't know if you are running a alternator or not plus make shore your battery is good. Tony K. |
#16 |
Thanks I will check all my connections again. I believe everything i've checked so far have been 12volts or higher.
#17 |
Liked 2 Times in 2 Posts
No RPR points this weekend?
#18 |
No I'm gonna sit this one out. I hope to get it back and tested for Lufkin the weekend after.
We may go camping this weekend to get away lol! |
#19 |
Liked 312 Times in 175 Posts
Not sure about dyno testing the converter. IMO you should send it out and cut it apart.
#20 |
I think they are going to dyno 1st and then cut it open and look at it.
If it was electrical/low voltage issue wouldn't it pop under heavy load? |
