Old 03-26-2017, 02:35 PM   #1
J.R. Haddad
Liked 1,463 Times in 307 Posts
Default Metric 200 question
I just looked at my metric 200 case, getting ready for spring, and it has
the dreaded bell housing crack. I have another case, but it has the
solenoid plug for a lockup which mine does not have. Can I swap
the internals, or do I need the non-lockup case? Thanks, J.R.
J.R. Haddad is offline   Reply With Quote
Old 03-26-2017, 02:51 PM   #2
Hacksaw
Liked 308 Times in 173 Posts
Default Re: Metric 200 question
Have a competent shop Tig weld it for you.
Old 03-26-2017, 03:04 PM   #3
J.R. Haddad
That's my 3rd or 4th option, trying to find out about the cases. J.R.
Old 03-26-2017, 03:38 PM   #4
ZenzenRacing
Liked 53 Times in 17 Posts
Whose trans is it?
ZenzenRacing is offline   Reply With Quote
Old 03-26-2017, 03:48 PM   #5
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
You should probably replace the case with a pre-1981 case , so that your spacer plate and VB will be compatible . Hopefully you are not running a solid transmission mount , which would put extra stress on the case . Also did you cut the "ears" off the bellhousing for header clearance ? Sometimes that creates a stress riser .
Old 03-26-2017, 04:06 PM   #6
J.R. Haddad
Ron, it was built by Dynamic. No, don't run a solid mount, but replaced
what looked like a tired beat up one with a new hard rubber one last
year. No, didn't cut the ears off. J.R.
Old 03-26-2017, 04:32 PM   #7
ZenzenRacing
We broke two cases until we went with McClay with the strut on it for the Corvette. No problems since.
Old 03-26-2017, 05:54 PM   #8
MR DERBY CITY
Liked 7,900 Times in 1,512 Posts
The brace on the pass side is a must have item....If you really want to sleep at night call Leo G. For the replacement bell housing. Money well spent and far superior to the factory metric case.....
Old 03-26-2017, 06:45 PM   #9
Daran Summerton
Daran Summerton's Avatar
Liked 66 Times in 37 Posts
J&W Ultra bell
72 cutlass
Daran Summerton is offline   Reply With Quote
Old 03-26-2017, 09:16 PM   #10
cmracing
Liked 62 Times in 29 Posts
Worked on a KS/A with a Metric 200 and I remember calling a trans guy to see if that brace needed to be there. Never saw anything like that before. I left it after being told DO NOT TOUCH IT!
cmracing is offline   Reply With Quote
