Old 02-15-2017, 07:25 PM   #1
Marty Hignight
Liked 23 Times in 14 Posts
Default Powerglide first gear
So I am thinking of getting a powerglide for my car, it weighs 3024 with me, I run super street, only have about 500 hp in a small block. what first gear would be best?, it has 4:56 rear gears
Thanks in advance
Marty
Marty H
Marty Hignight is offline   Reply With Quote
Old 02-15-2017, 09:27 PM   #2
Hacksaw
Liked 315 Times in 178 Posts
Default Re: Powerglide first gear
198 ATI super set
Old 02-16-2017, 02:17 PM   #3
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Thanks in advance
Marty
What transmission are you currently running? What ET and MPH?
S/ST 51
S/C 53
Old 02-16-2017, 02:49 PM   #4
jmcarter
jmcarter's Avatar
Liked 3,262 Times in 990 Posts
I'd agree with the 1.98's but you need to know your torque readings or have a good idea that you can stand that kind of drop when you go into 2nd. Be prepared for the car to slow down if you had a good 3 speed before.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 02-16-2017, 05:30 PM   #5
Lenny5160
Lenny5160's Avatar
Yeah, I can't imagine a 3000+ pound car with 500 hp is very far below the index as it is.
With a 1.98 first gear and 4.56 in the back, it will work the same on the starting line as it would with a standard 1.76 first gear and 5.13 in the rear. The 1.76 combination would recover better on the shift also.
I doubt a 500 hp motor will like a lot of RPM, but there are a lot of variables.
S/ST 51
S/C 53
Old 02-16-2017, 08:57 PM   #6
Marty Hignight
Right now a c4- only have 1/8 mile data right now last weekend flat out was 6:58 @ 103 mph. Going to test 1/4 mile this weekend.
Thanks for the info
Marty H
Old 02-18-2017, 07:41 AM   #7
Robbie Welch
Liked 262 Times in 124 Posts
Your going to slow down your C-4 is plenty good for your weight and power.
Old 02-18-2017, 09:30 PM   #8
Dick Butler
Liked 32 Times in 19 Posts
More gears better in that weight range but probably regardless if set up.
Old 02-20-2017, 01:34 PM   #9
Tom Goldman
Tom Goldman's Avatar
Liked 889 Times in 239 Posts
I'd stay with the C4 with the power level you have , No problem hitting the .500 tree with that combo.
I have several Super Street customers who run 3 speed transmissions because their car is a heavy weight .
If it was my car ,I'd keep the C4.
Old 02-20-2017, 01:50 PM   #10
Lenny5160
Lenny5160's Avatar
My Super Street car weighs 3575# and runs a 1.80 glide with 4.30 rear gears. I have more power but because of the weight I am only a little quicker on ET. Runs right around 10.30 wide open and goes 10.90 at about 127.
With a Pro Tree transbrake I am leaving at 3800 RPM with .050-.060 in the box, so no problem cutting a light.
S/ST 51
S/C 53
