Old 01-01-2017, 12:41 PM   #1
Kdw1403
Liked 68 Times in 22 Posts
Default LT 1 350 valve to piston clearance
What is minumun valve to piston clearance? i have .100 on intake and .60 on exhaust. I am a little nervous about exhaust side. Is it legal to cut the exhaust valve pocket on the piston just a little? nhra stocker
Kdw1403 is offline   Reply With Quote
Old 01-01-2017, 01:14 PM   #2
Bob Gullett
Bob Gullett's Avatar
Liked 510 Times in 117 Posts
Default Re: LT 1 350 valve to piston clearance
Is that checked with checker springs or the regular springs?
68 Chevy11 327 F/S
Bob Gullett is offline   Reply With Quote
Old 01-01-2017, 01:42 PM   #3
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
I do not think so.
265 55 Chevys sure wish they can notch their flat pistons to get some valve tolerance.
D
Old 01-01-2017, 02:10 PM   #4
Ed Wright
Ed Wright's Avatar
I do not think so.
D
Having raced 265" '55 & '56 Chevies, we damn sure flycut our flat top pistons for valve-to-Piston clearance. Mine was down 4 times by NHRA, three national records & once was protested, passed every time.
Ed Wright 4156 SS/JA
Old 01-01-2017, 02:15 PM   #5
Liked 1,927 Times in 433 Posts
No, it is not legal to cut the valve reliefs on pistons in NHRA Stock Eliminator.
I would probably consider 0.060" piston to valve clearance on the exhaust to be the minimum safe clearance, if it was properly checked to begin with, and you have very good valvetrain control.
Old 01-01-2017, 02:29 PM   #6
MR DERBY CITY
Liked 8,224 Times in 1,538 Posts
Ed, we are talking STOCK eliminator.....Alan is correct. I might add just watch yourself in the water....
Old 01-01-2017, 03:44 PM   #7
Ed Wright
Ed Wright's Avatar
I apologize. The Stock rules are different enough from when I ran Stock with that '56, I should have kept quite. About all he can do legaly is move the cam.
I don't get the remark about water?
Old 01-01-2017, 03:55 PM   #8
TOSTO RACING
TOSTO RACING's Avatar
Liked 665 Times in 187 Posts
I think he is referring to don't let it get away from you on a burnout. People tend to over rev a car in the water box.
As for vtp like Alan said above .060 .065 exh would be as tight as I've ever ran and it was okay for me. The intake is more forgiving. if I were you I'd advance the cam and get yourself some more exh clearance and less int in my opinion if you are worried about it .
Good luck with it.
5664 GHI/SA
1985 CAMARO RED H/SA --- FOR SALE
1985 CAMARO BLUE I/SA --- FOR SALE
TOSTO RACING is offline   Reply With Quote
Old 01-01-2017, 04:01 PM   #9
Ed Wright
Ed Wright's Avatar
Good luck with it.
Need to use a rev limiter in the water. I run .040" on the intake side a lot, have run .035" and they never touched. Had clean intake pockets. No carbon. I've never run less than .065" on the Ex side. Right now, mine has .040" & .070". Nothing touches.
Old 01-01-2017, 05:31 PM   #10
Dan Fahey
Dan Fahey's Avatar
Curious. Why more Clearance on the Intake vs Exhaust. ?
