Old 12-24-2016, 09:51 AM   #11
Shaun Quill
Liked 105 Times in 26 Posts
Default Re: Electric radiator fan recommendations
Originally Posted by joe huestis View Post
Shaun,
I own a 2011 HHR as my daily driver. That's an idea. Hmmm...
I don't know what the CFM rating is on it, but when you turn that thing on you know it !!! It pulls some pretty serious air .
Old 12-24-2016, 10:03 AM   #12
GTOMayhem
Liked 22 Times in 14 Posts
Originally Posted by RobbieRacer View Post
It's a lot of amps to pull thru the switch. The wire can get real hot. This way the switch only triggers the relay.
A little off topic, but are there any books that cover basic race car building? That would answer wiring questions and such. Seems most racers, even seasoned ones, have many different methods to builds.
Rick Thomason
GTOMayhem
GTOMayhem is offline   Reply With Quote
Old 12-24-2016, 10:09 AM   #13
terry1
Liked 24 Times in 13 Posts
Smile Re: Electric radiator fan recommendations
The book I use the most is the cheque book!
terry1 is offline   Reply With Quote
Old 12-24-2016, 02:10 PM   #14
Liked 5,077 Times in 1,935 Posts
Originally Posted by MikeMoller View Post
Why is a relay needed? Just curious, I've never used a relay, just a toggle switch and an inline fuse.
If you use your standard 30 amp relay and spade connectors, you might want to squeeze them a bit with pliers. I've seen them melt and burn up at that point.
Old 12-24-2016, 04:29 PM   #15
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Good heavy duty switches are hard to come by. Stop by your local small engine repair shop and have them order you some chain saw switches...chances are they won't have any in stock because they never fail. They will utilize a screw terminal instead of spade connectors.
!0-4 on the relays...make a world of difference. Quality stuff here... http://www.leashelectronics.com/
Good reading/advice here... http://www.madelectrical.com/electrical-tech.shtml
Rich Taylor
I/SA - 321
Old 12-27-2016, 11:51 AM   #16
Mike Pearson
Mike Pearson's Avatar
Liked 1,903 Times in 571 Posts
If I remember correctly I bought mine at the local parts house. Advanced Auto parts. Nothing fancy but works well cools good and has been reliable.
Mike Pearson 2485 SS
