Old 12-27-2007, 07:00 PM   #1
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Red face Rear brake drum help!!??
Hey guys I need some help.....pulled the tires off the cutlass last night...it has one alum. drum on one side & a cast iron smooth one on the other. The brake shoes look OK but not real good so I'm going to replace them....now then how do I get or where can I get a smooth cast iron or an alum drum so I can match things up? I went to Advance tonight & YEP we have them....yea...cast iron finned! NOT going to work WAY to heavy! so any ideas? I had the guy look up some other cars & all had the finned cast iron! OH almost forgot the car is an 88 olds ctulass with an 8.5 10 bolt.....drums are 9.5" inside dia. shoes are 2" thanks guys!
Old 12-27-2007, 07:04 PM   #2
Doug Blackley
Doug Blackley's Avatar
Default Re: Rear brake drum help!!??
Easier to find the alum drums on Ebay than scouring local boneyards.
Doug Blackley 1697 STK
Old 12-27-2007, 07:29 PM   #3
Lyn Smith
Liked 997 Times in 201 Posts
Greg, If you need a smooth steel drum, I can help you out. Have Good New Year .Lyn 815 844 7852.
Old 12-27-2007, 10:55 PM   #4
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
Try looking for rear drums for 67-9 camaro 10 bolt, should be the smooth ones, can still get them from napa up here in the snowy north!
Old 12-28-2007, 10:23 AM   #5
Bill Pomponi
Maybe can help you out with either an aluminum or CI drum. What part number is stamped in the aluminum drum you have?
Bill Pomponi is offline   Reply With Quote
Old 12-28-2007, 12:12 PM   #6
Dave Goob Cook
Dave Goob Cook's Avatar
3rd gen Camaros from 86 up should be a good place to find the Aluminum drums.....
Be aware though that I have experienced a loss of brake "hold" on the line with the Aluminum drums....proper arc of the shoes would be particularly important, always use NEW shoes, not relined.
I went back to the old reliable finned iron drums.
Dave Goob Cook is offline   Reply With Quote
Old 12-28-2007, 01:38 PM   #7
Stevie Ficacci
Stevie Ficacci's Avatar
I have a couple sets of aluminum drums is you decide youd rather have aluminum.
Steve Ficacci
1142 G/SA
Stevie Ficacci is offline   Reply With Quote
Old 12-30-2007, 03:44 AM   #8
Duane Eiskant II
Duane Eiskant II's Avatar
Liked 57 Times in 33 Posts
Have someone you know that has a brake lathe and they can smooth out the cast iron drum. Just takes a little time. Also you can turn down the big lip (some fords have them, not sure on the cheby stuff). It should save on some weight...But with the price of shoes and drums, have you priced the aerospace rear kit yet?
Lil Duane
Duane Eiskant
1354 Stock/Super Stock
Duane Eiskant II is offline   Reply With Quote
Old 12-30-2007, 08:33 PM   #9
Ken Haase
Hey Greg, if you want to follow Duane's advice, I have a new-in- box Aerospace setup for 10 and/or 12 bolts with C-clip eliminators.
Ken
Ken Haase is offline   Reply With Quote
