Liked 22 Times in 14 Posts
Rule book states:
INTAKE MANIFOLD Must retain the unaltered stock manifold, consistent with year and engine horsepower claimed. Grinding, sandblasting, or any other modification to manifold prohibited. Any film coating inside manifold prohibited. Runners and plenum must retain OEM appearance. Final acceptance at the discretion of the NHRA Technical Services Department. I know it is common practice with Pontiac intakes to separate the coolant crossover from the intake, to allow a better intake to port alignment. Is this practice used in Stock Eliminator? Also, is the modification restriction only apply to the actual intake ports? Or can one modify cooling passages? Rick Thomason GTOMayhem |
Liked 239 Times in 114 Posts
INTAKE MANIFOLD
Must retain the unaltered stock manifold, consistent with year and engine horsepower claimed. This says it all . I would not try to pass tech with the coolant crossover cut off the manifold . |
What about blocking the small exhaust holes under the front of a quadrajet on the 67 only Pontiac intake?
You can do that by getting a different carb gasket . So there won't be any modification to the manifold . Those passages probably don't do much if you filled the exhaust crossover ports in the cylinder head , which is a legal modification .
Liked 783 Times in 195 Posts
Work to align the intake ports; the water passage will take care of itself. People have been racing Pontiacs in Stock Eliminator for over 50 years and I do not think any slight misalignment of water passages in the intake manifold has ever been an issue.
Liked 103 Times in 35 Posts
Fill the exhaust crossover in the heads. Do away with the water pump o ring to manifold (grind it down and put a pipe plug in). This will allow you to shift the intake back and forth to align the ports. Ron.
#7 | |
Rick Thomason GTOMayhem Last edited by GTOMayhem; 08-12-2016 at 05:36 PM. |
#8 | |
Liked 5,147 Times in 1,964 Posts
Not sure where you're going with this, Rick. You can block off heater ports on an intake. Also , you can block off w/p bypasses with a plug . Of course, it can be done at the thermostat housing (i.e. Olds, BBC) or at the water pump or block..(SBC).
Liked 54 Times in 33 Posts
Old school ideas persist. Sure, some are ok, but after having to test everything Pete McCarthy and other known back yard specialist ever said I found out 98% of what they shared was home grown myths. Which is understandable.
But, I want equal heat in the chambers. You do too. A hole only the size of .100 thou will transfer enough water to get the job done. I'll hazard a guess my offset from the Xover to the timing cover is as big as anything you've seen. It retains the o-ring and carefully placed RTV. Mine is S/S so I can separate the X over. Works on the S/S baddest Pontiac engine combination on the planet. Why wouldn't it work for you. And you don't have all that fussing drilling and tapping and probably some grinding. Won't be long. NHRA will allow Stockers to cut off the X over. Bet? |
Thanks for everyone's input. The knowledge base here is second to none. Those of us that are new to Stock Eliminator ask some unusual questions sometimes, but we always get answers. Not always the ones we expect or even what we thought we already knew. Sometimes the answers bring even more questions.
Mark you have a PM. Rick Thomason GTOMayhem |
