#21 | |
Liked 7 Times in 6 Posts
#22 |
I've had no problems with drum brakes all around, both on my '70 Nova and now my '67 Camaro in E/SA w/396. I believe the size is only 9 1/2" x 2 1/2", the original 6 cylinder brake setup, and all the parts were new- drums, springs, wheel and master cylinders, lines, hoses, the works. The stuff was straight from the auto parts store, nothing fancy. Car holds fine on the line at 3500 on the converter, can stop with no problems on the top end. The Nova was 3570 lbs with driver, Camaro is 3420 lbs., running upper 10's at 121.
My 2 cents is the expensive shoes are intended to stop better on heavy, prolonged and repeated braking, when they get hot. Quite possible that the cheap shoes work just fine for what we do, stopping once with lots of room to do it. Might be different on a very short track where you need to really stand on the brakes all the way down to the turnoff... Grant Eldridge E/SA 6650 |
#23 |
Liked 4 Times in 4 Posts
i run a 1968 mustang 428cj , 4 speed, 10.60 @ 129 . 3450 with driver. with the stock 4 wheel drum brakes. i dont really like how it stops sometimes and have been thinking about going with strange discs on the front and the factory drums on the back. what do you guys think of the strange front brakes? ron b
#24 |
Liked 46 Times in 29 Posts
I know this is an old thread. But it is holding relevance to me currently. I am looking at replacing rear brake shoes and buying 2 sets as to use the secondary shoes of each set only. This is my 70 Chevelle for 10.0 index and bracket racing. It's the last repair I'm making and I'm ready to go. I see Mark Yacavone mentioned you can do it and it's what I had planned to experiment with but brakes are most important to our cars. 3800 pound stock suspension. It is built sticker like with the dream cause stockers are way cool. Chris
#25 | |
Liked 759 Times in 379 Posts
I tired it all with my Chevelle...new drums, aluminum drums, 4 secondary shoes, aftermarket disc brakes replacing the factory disc brakes up front and finally 11" rear brakes which fixed staging issues as well better braking down track. Last edited by 1320racer; 07-17-2016 at 11:44 AM. |
#26 |
Thanks Ed
I will look into both options I have strange c clip eliminators with their 35 spline axles. I think the center hub is different diameter than stock as I had to open up drum to fit it over. Lot to think about. |
#27 |
Liked 133 Times in 76 Posts
When I built my car I set it up to footbrake. I have a Ford 9" in the back and used 2 sets of shoes so i could have all long lining covered shoes. Then I took the wheel cyls and with the help of a local parts store found the largest diameter wheel cyls that fit my backing plates. When footbraking the rear drums have great holding power as they are self energized, the shoes try to rotate against the drum which in turn forces them out harder as the lead shoe grabs. Also basic hydraulic principles, the larger the wheel cyl bore the more the hydraulic line pressure is pushing the shoes.
#28 | |
Liked 16 Times in 7 Posts
#29 |
Liked 53 Times in 38 Posts
Watch out putting long shoe on front, it might energize to much and lock up. That short shoe is done for a reason.
#30 |
Liked 10,930 Times in 2,258 Posts
Don't forget to check the backing plates for mounting hole distortion. We had to change ours out after two or three years of using a two-step,
