Old 05-20-2016, 01:15 PM   #11
Rick Leininger Jr.
Default Re: LS3 Head
Originally Posted by Adger Smith View Post
I have always wondered if you could use the iron LS heads successfully in SS/CS. It would be easy to build a small 286 cu in LS to make class minimum weight. Has anyone tried it?
Hey Adger, how are you?
Not currently pursuing it, but collected a few LS blocks & LS iron heads for this combo. The blocks will handle a 60mm cam bearing and .937" lifter bushing no problem. The lowest deck height block offered is 9.230", but of course that can fixed. The LS iron heads have the same intake & exhaust ports as the LS6 head, but the chamber is open and rather large at ~71 cc's, so some welding the chamber up and possibly rolling would be needed.
Rick Leininger Jr. is offline   Reply With Quote
Old 05-20-2016, 02:56 PM   #12
Glenn Briglio
Glenn Briglio's Avatar
Liked 976 Times in 311 Posts
Glenn, they changed their ruling and the cylinder heads can used in the Modified class only. Not in the regular SS or GT class.
Thanks for the update.
