#41 |
Liked 56 Times in 21 Posts
Todd amen
Vic Guilmino 1129 STK |
#42 | |
Liked 184 Times in 113 Posts
Hardly warmed over! Custom Tunnel Rams which look like todays COPOs. The Cylinder Heads were cut and welded together. Special Alloy Pistons..Rods...cams and stable rocker systems. Systems to reduce parasitic drag such as dry sumps. Stuff we all can buy right off the shelf! The 327 cuin was about the largest SBC engine to make power/weigh with back in those days. No magic because the principles to make power then the same today. One exception; the Big Three used a clean sheet of paper to incorporate all the best stuff developed in the past. Even that stuff is not perfect enough to get another half second of power. Super chargers and turbos were after thoughts. Today they are integral as and entire designed package. Supercharged B/G cars with huge Superchargers are today's Supercharged Super Stockers. Just with 40-50 years of technology packaged and reclassified! |
#43 | |
Guest
Posts: n/a
There is no other way to improve a combo? Tuning, testing ect? Just do the heads and let it rip? Last edited by Todd Hoven; 03-27-2016 at 12:55 PM. |
#44 |
The cylinder heads are also available unported and raw.
#45 |
Liked 708 Times in 285 Posts
I would think clarity of the article would help. I reread the article and title of article and could not find the words "building a factory stock shootout engine." Sounds minor but would clear up this confusion about allowing heads to be ported with a cc max because NHRA can not police it in stock.
#46 | |
Which is it? |
#47 |
Liked 7,892 Times in 1,754 Posts
That kinda depends on which side of the rules you want to walk on, doesn't it?
#48 |
#49 | |
Guest
Posts: n/a
I guess is what I'm trying to say is that the CNC program that is used to profile the heads I'm sure has been researched and pretty close to the best you can buy. IMHO. I think unless you have spent time with one of these engines you don't realize how good the parts are that used in these engines. |
#50 |
These cars are all certainly "stock eliminators"!!
