Old 11-12-2015, 07:21 PM   #31
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
Default Re: Boss Mustang stocker
The heads in the picture are ford DOEA-N heads not edelbrock the casting number is on the head plus it has a Cleveland combustion chamber the edelbrock doesn't .
7015 E/SA Sooner Storm
astikhossw is offline   Reply With Quote
Old 11-12-2015, 07:31 PM   #32
Bill Diehl
Bill Diehl's Avatar
Liked 9 Times in 8 Posts
correct, that's exactly what they are... cast iron and for the others that are dying to know...they are well within the rules, they hold the proper volumes...no grinding, porting, acid, bead blasting, epoxy or any of that other cheating BS... they have 16 seats installed and a proper valve job on good ole ford cast iron.
I been working this style head over for 40 years...this is the best set ever
Edit...I posted last year in one of the threads where I got beat up that it is easy to get these to go 325+ at .500 with the right "stuff"....you all can do the math but this set blows those away....since the cats out of the bag, I mine as well turn this into an educational thread...stay tuned..LOL
Bill Diehl B200 C/D STK
Bill Diehl is offline   Reply With Quote
Old 11-12-2015, 07:35 PM   #33
Bill Diehl
Bill Diehl's Avatar
Originally Posted by FireSale View Post
Thanks. That's the area that caught my eye. Are the fenders still removable?
Dale
yes, I will try to find a pic to show you what we did on the past on the faster cars, but now that it is legal for stock....its all good
Old 11-12-2015, 07:59 PM   #34
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
For anyone really interested in seeing what a good job Bill has done on these heads, here is a link to specs on MustangTek with rusty photos.
http://mustangtek.com/heads/D0AE-N.html
EDIT: Re your edit: I don't think anyone on this particular thread has anything other than positive interest in your build. We (at least me) are curious because we all like good stuff.
Dale
Dale Shearon
68 Mustang 6394
Old 11-12-2015, 08:23 PM   #35
Bill Diehl
Bill Diehl's Avatar
Dale
Its all good Dale...stay tuned
Old 11-13-2015, 12:21 AM   #36
Dave Noll
Dave Noll's Avatar
Liked 238 Times in 111 Posts
I think wer'e looking at a BOSS 351 '71 Mustang. Those might be Edelbrock heads part number 61607. They are listed as legal for both Stock and SS. They ship as bare heads and the buyer has to have all the machining done. That seems to be the case here.
Dale
Not quite. The 61607 isn't legal for stock on the Boss. It is on the 240hp (what I'm running) the 280hp & the 285hp. The 71 Boss is rated @ 355hp with the iron head. In SS the iron head is @ 330 and the Edelbrock is @ 340.
In this thread there is an Aluminum head pictured (with the recess around the crossover) and those real nice looking D0AE-N's.
And yes, I'm nothing but supportive of seeing another 71 Boss hit the track. If I had more resources, I'd have the 71 285hp in my Cougar which the Boss wasn't available in.
Looking forward to more post's on this build.
Dave Noll, EF/S ,?/SA 6526
Old 11-13-2015, 05:24 AM   #37
Bill Diehl
Bill Diehl's Avatar
Dave, that pic I posted with the recess around the crossover is my cast iron DOAE_N heads..... this should clear things up.....the 61607 eddy head does not have a crossover
Old 11-13-2015, 07:51 AM   #38
Dave Noll
Dave Noll's Avatar
Whoops, sorry about that, . With the shiny from that fresh mill cut across that face, I mistook it for aluminum. My bad.
Old 11-18-2015, 08:34 PM   #39
Bill Diehl
Bill Diehl's Avatar
I am waiting for the strut rod crossmember to show up,so I can start putting the front end back together but.... before I open the next can of worms.....I have seen these on plenty of cars but I can't find the word roller bearing in the rule book under front suspension anywhere...maybe somebody with better reading skills can help me out
Old 11-19-2015, 09:27 AM   #40
Bill Harris
Liked 26 Times in 13 Posts
The opentracker roller upper and lower control arms are legal, as is the roller spring perch. I had the whole mess on my '71, including the double-roller spring perches (expensive) and you will be absolutely astonished at how freely the front end moves. The alignment guy loved it too. Don't forget to notch the upper frame rail where the upper arm hits to get a bit more suspension travel on launch. You will need to lower the upper shock mount at the same time to keep the shocks from bottoming out. It will be easier to find shocks if you use the earlier "T" upper mount instead of the single stud version that came on the '71. Get the best double adjustable shocks you can. I used the Calvert shocks and they are awesome for launch, but are way under-damped when landing after a wheelstand and the car bounces way too much. What is NOT legal are modified strut rods, like the Calvert with the spherical bearing. They are OK in SS but not in stock. The stock strut rods work just fine. Poly bushings make it stiffer but perhaps a little more stable on the top end. I would just use new rubber bushings if it were me.
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
