Old 07-29-2015, 06:29 PM   #1
Tony Goodman
Liked 18 Times in 4 Posts
Default Transbrake on 9" tire.
I'm running a 97 LT1 Firebird in stock. If I was to run Superstock how well would a stocker chassis work with a transbrake on 9" radial tires? Anybody out there doing this? Thanks Tony
Tony Goodman is offline   Reply With Quote
Old 07-29-2015, 07:20 PM   #2
Eric Merryfield
Eric Merryfield's Avatar
Liked 503 Times in 131 Posts
Default Re: Transbrake on 9" tire.
I am running a 9 inch radial on my GT/TD truck, but I don't run a transbrake as the truck works well enough with the stocker i.e. leaf spring and cal tracks setup to hook everywhere.
You would need to likely make a few changes if you go the transbrake route as you obviously would be going from loaded chassis to unloaded at launch. 9 inch radial tires might prove problematic for a transbrake hit, just like they are for stick cars.
Eric
Eric Merryfield 1883 STK
Old 07-29-2015, 07:35 PM   #3
denbreeden
denbreeden's Avatar
Liked 67 Times in 27 Posts
I run my Drag Pak in Super Stock, 9" radial tire and a transbrake. No issues with my car.
Dennis Breeden
denbreeden is offline   Reply With Quote
Old 07-30-2015, 08:03 AM   #4
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
I run a 9" radial tire and a transbrake. No problem if the track is "preped" ....
Old 07-30-2015, 10:18 PM   #5
countrypuppy4865
countrypuppy4865's Avatar
Liked 229 Times in 71 Posts
My concern would be spinning on a marginal track. If you are running a heavier class in SS (such as SS/KA with this combo), I feel like they would probably work because you have the ability to move a bunch of weight around.
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
