Old 10-25-2014, 08:09 AM   #1
FrankChastain
Location: Trussville, Alabama-Originally from Vidalia,GA
Default Windshield Washer Message
Need some help on a 07 5.3 GMC Sierra pickup. The warning message comes on the windshield washer is low every time I start it up, but it's not
it's full. Goes off when I reset the mileage. Any help would be appreciated.
FrankChastain
FrankChastain is offline   Reply With Quote
Old 10-26-2014, 01:25 AM   #2
Rob Petrie E395
Liked 216 Times in 77 Posts
Default Re: Windshield Washer Message
Take a look at the sensor in the tank. It probably has something on it. After you clean it or replace it ( I would recommend replacing it). IF you dont have a scan tool to reset it. Sometimes you can disconnect the battery for 2-4 hours and it will reset. While you are at it take a look at the connector in the wiring harness and make sure it is not corroded. If it is you can get a new one from NAPA.
Old 10-26-2014, 06:20 AM   #3
FrankChastain
Thanks Rob for the info.....Thanks again Frank
