Old 09-18-2014, 11:57 AM   #91
Mike Pearson
Mike Pearson's Avatar
Liked 1,956 Times in 591 Posts
Default Re: Part of what hurt drag racing
Down here in Div 2 we have 3 heads up classes that run at our points meets. 10-0 11-0, 12-0. No throttle stops allowed. Very low car counts for the past two years. I don't think heads up is the answer. Better promotion and more realistic purse money will bring the cars out. Michael Beard is a top notch racer and promoter so he could give the best advice for this topic. Listen to what he has to say.
Mike Pearson 2485 SS
Old 09-18-2014, 12:18 PM   #92
randy wilson
Liked 22 Times in 22 Posts
Are you talking about
10, 11, and 12 lbs. per cubic inch, or 10, 11, and 12 seconds.
don,t have one
Old 09-18-2014, 12:47 PM   #93
rognelson777
Liked 135 Times in 74 Posts
It is a problem that cannot be fixed and here is why,
What was Drag racing originally, Heads up with with 1st to the finish line.
US nationals 1968 how many categories/classes raced 20?
All I believe were 1st to the finish line. 20 winners.
How many class race winner at Indy this year 200?
What changed, mostly money, those who spent the most usually won.
Everyone suggests a entry level class and different rules, These rules are already in place, Just run class eliminations, no bracket racing.
Unfortunately, car count will go down and we will go back to where we are today.
rognelson777 is offline   Reply With Quote
Old 09-18-2014, 03:14 PM   #94
Mike Pearson
Yes they are 10, 11 and 12 second index cars. There also used to be some 5.50, 6.50 and 7.50 heads up index racing at the 1/8 mile tracks down here but I think that has all but dried up too.
Old 09-18-2014, 03:26 PM   #95
Dick Butler
Liked 32 Times in 19 Posts
mike pearson, if the classes were based on seconds then there were break outs Right?They could "pedal"it at the end to win?
Rognelson: Class racing is wonderful if you have a one combo class. The minute someone finds a loop hole car or bogus motor end of story. I raced GT/AA for several years and it was great. Only two combinations were running and they were a coin flip on hp rating. Then Small block combination runnin1000 lb lighter same class. Then bogus Truck motor. Result several years of fewer equivalent cars to race for trophy.
IF one motor per class or based on lb per cubic inch same specs that is REAL class racing....
Also Class racing with current rules can be very expensive due to wild equipment and machining available.
Old 09-18-2014, 03:36 PM   #96
randy wilson
Brodie spec. Same head flow, all 3 manufacturers.
don,t have one
Old 09-18-2014, 04:04 PM   #97
randy wilson
Brodix, dang spell check.
don,t have one
Old 09-18-2014, 04:45 PM   #98
Mike Pearson
Yes they could peddle it but both cars leave at the same time and run hard to the end. Not like the Super categories' that use the electronic throttle stops that bog at the start. plus with the 3 classes you fall into the one that is closest to your target number. They are definitely entry level classes. and heads up. The index thing just keeps the cost down. What you are talking about is heads up no break out. It could be done but the cost would be very high to be competitive. Look at comp or any other no break out class. Huge bucks. Just look at what happened to top stock. Good for a few years then the big buck guys killed the class and now its gone
I was watching the online coverage of one of the IHRA points meets earlier this year and from watching that coverage the most boring class was the SC dragsters. They are like watching paint dry. No wheels up action. They all look the same. The stupid throttle stop thing make it even worse. Drop the indexes on the super categories by a second and a half it might be a bit more interesting.
There is no cheap way to go class racing. I am not real fast but enjoy what I do.
It all boils down to the track operators promoting the show that they already have to put some butts in the stands. No matter what kind of class you have running if there is no promotion there will be no spectator interest. When is the last time you saw any type of advertisement for a local race of any sort. Not even a mention on the sports report on the local news unless something bad happens. Its not up to the racers to promote we provide the show.
Old 09-18-2014, 05:05 PM   #99
Rusty Davenport
Liked 101 Times in 27 Posts
Mike----I dont think that is the "heads up" Randy and the guys are looking for-----heads up is same rules both cars------- first man wins is what they are looking for.
NHRA AND IHRA STOCK ELIMINATOR 2772
Rusty Davenport is offline   Reply With Quote
Old 09-18-2014, 05:10 PM   #100
Lou Jeffery
Originally Posted by James Perrone View Post
What has killed drag racing is ..ALL YOU KEYBOARD RACERS...Get out and RACE,
Stop trying to change the world..Most of you guys don't class race WTF...Nothing in life is fair.. I race cause I enjoy it life is too short..Get out and race!!!
James, I LOVE YOUR COMMENT!!!!!!!!
Lou Jeffery is offline   Reply With Quote
