Had problems with shubeck lifters (Lifter puck desintregated on dyno 2 times). Customers wants to run tool steel lifters in a 64 MaxWedge426. How much spring pressure should I run with them? Thank's!
Liked 20 Times in 9 Posts
Don't know about how much spring pressure you can have on tool steel,But how much spring pressure did you have on the Smith lifter when it shattered and how much rpm.Just curious .
7015 E/SA Sooner Storm |
235 valve closed, 570 open, ran those lifters for 9 tears wiyh the same combo without any issues.
Liked 1,878 Times in 422 Posts
With the correct tool steel lifter, and camshaft, with the correct surface treatment, you can run as much as 550 open pressure.
Do not, under any circumstances, run a DLC coated tool steel lifter on a cast iron core camshaft.
Alan Roehrich 212A G/S |
