Old 05-05-2014, 02:31 PM   #1
Greg Marshall
Greg Marshall's Avatar
Liked 10 Times in 6 Posts
Default Data recorder for stocker
Looking to buy a Data recording system for my Stocker, mainly to determine correct jetting so iam thinking a system with two O2 sensors and being able to playback the run. I have heard Racepak are the best but lots of $$$ Any info on other brands would be great.
thanks
Greg Marshall is offline   Reply With Quote
Old 05-05-2014, 03:51 PM   #2
howes1387
Default Re: Data recorder for stocker
i would recommend the new autometer tach, has everything you would need in a small package and at a great price.
http://www.autometer.com/cat_data_ta...il.aspx?pid=17
howes1387 is offline   Reply With Quote
Old 05-05-2014, 05:50 PM   #3
Greg Marshall
Hello Howes,
Does the autometer tach have connections for O2 sensors?
Old 05-05-2014, 06:01 PM   #4
Liked 1,924 Times in 432 Posts
Daytona Sensor.
Old 05-05-2014, 06:31 PM   #5
Greg Marshall
Hi Alan, Daytona sensor can i buy the O2sensors and computor as a package? thanks
Old 05-05-2014, 06:37 PM   #6
Yes, you can.
They have a nice little system that has two wideband O2 sensors, engine RPM, and with a sensor setup sold separately, driveshaft RPM. It also has programmable shift lights, so you can set each gear to a different color and RPM, and also program a staging RPM indicator light, for use in "no box" races, so you stage at the same RPM every time. I've sent them several customers, all of the customers have been really happy.
Old 05-05-2014, 06:57 PM   #7
Myron Piatek
Liked 138 Times in 51 Posts
Thumbs up Re: Data recorder for stocker
Originally Posted by Greg Marshall View Post
Hello Howes,
It has one channel for a single O2 sensor as well as one for a pressure sensor, + several other very helpful features all in one package. This video from the 2011 PRI show will provide more info.
LOCOMOTION Racing
Old 05-11-2014, 11:15 AM   #8
Altronics
Sponsor
Altronics's Avatar
Liked 63 Times in 11 Posts
Check out our O2ALERT system. It features two wideband O2 sensors, Tach, Battery Voltage, Warning output, plus optional pressures, drive shaft RPM and EGT.
PLayback direct on unit or download with included software.
Click here for more info-> http://www.altronicsinc.com/air-fuel...ecorder-1.html
Fred Bartoli
847-923-0002
Altronics is offline   Reply With Quote
Old 05-11-2014, 11:03 PM   #9
kdanner
kdanner's Avatar
Liked 38 Times in 17 Posts
I don't see anything called Ultimate DL, Daytona, or O2Alert in the listing of approved data loggers. Are these things not checked in tech?
K Danner STK 468
kdanner is offline   Reply With Quote
Old 05-12-2014, 10:12 AM   #10
Altronics
Sponsor
Altronics's Avatar
The O2Alert is approved by NHRA and IHRA and is an IHRA contingency item.
Fred Bartoli
847-923-0002
