Who sells a replacement crank for super stock. 327ci . I read it on here but can not find it.
Liked 237 Times in 126 Posts
The rules say OEM or Accepted aftermarket crank only. Problem is, NHRA lists no aftermarket crank for the 327 Chevy. I'm a ford guy. so that's an assumption.
Technically, there are no aftermarket cranks for any Super Stocks as the list reads Stock Eliminator Aftermarket Cranks. For rods it separates Stock and Super Stock. The list is a bit of a joke. The only listed crank for my 302 Ford is an Eagle part that hasn't been made in 9 years. Eagle has submitted the replacement for approval several times but nothing happens. I just went with a forged crank that matched stock weight and specs. I'll plead dumb if they say anything. Dale
#3 | |
Fill this out add pictures and you should be there as long as all spec's are correct. http://www.nhra.com/userfiles/file/A...val%20Form.pdf Info http://www.nhra.com/userfiles/file/N...%20Process.pdf
Ross Gregory 5133 Stock,Super Stock 53 Top Dragster |
Thanks Dale, I called Callies they said they have a steel one that's on the list. $$$$$ ouch!
#5 | |
Thanks again. Dale
give me the part number and I can probably beat the price
Chad Rhodes 2113 I/SA |
In Super Stock, the rules stated it could not be billet (the forging line had to be visible, at least on the flange), and the counterweights could not be knife edged. They may have changed when aftermarket crankshafts were allowed in Stock.
You'll be hard pressed to find a small journal 3.25" stroke crank for anything close to a reasonable price.
Alan Roehrich 212A G/S |
Chad you have a PM. Your right Alan just have to save up and take my time.
Liked 358 Times in 83 Posts
I have a standard/standard, small journal, 3.25 steel crank that I would be willing to sell. If you're interested, send your phone number and I'll call you.
