#51 |
Due to the usual bickering that has evolved on this subject, I have not commented on this subject.
Nevertheless, in the engineering arena, analysis is based on Mohr's Law and for the proper lubricant selection, considerations are made on factors such as fatigue loading, friction, heat, corrosion resistance, kinematic problems, material properties, machining properties, machining tolerances, assembly and use. Therefore, most times, you have to arrive to a compromise with a lubricant solution that works based on recommendation and experience by either the vendor or a user. There is not a "Snake Oil" that meets all requirements and every manufacturer claims that "theirs is better or bigger" than the competition. |
#52 |
Liked 520 Times in 132 Posts
How do you come back after being banned? The other "Ed" was banned and never heard from again???? Just a question.
#53 | |
Liked 1,931 Times in 435 Posts
So if you're getting 200 passes out of yours, I'll stick with what I'm doing and getting about twice the gear life out of everything but that one set of 5.00 gears. Hey, Kenny, sorry about the bandwidth, but I found that the genius bragging about knowing more than me while getting half the life out of a set of gears that I do was just too funny. For the original post, yes, there can be power in synthetics, or at least ET and MPH. However, in the case of motor oil, it requires a ton of testing. You need to know what viscosity your engine requires due to the clearances and the oil pump, and you need to know what base oil and additive package makes your ring package happy. You could find a synthetic of a light viscosity that makes the engine real happy with regard to friction, oil flow, and pressure, but makes the ring package and cylinder wall finish very unhappy, and you may actually slow down. You need to talk to your builder and find out what the actual minimum viscosity for your engine is, and he should also know what makes the rings work. Some people have found that certain automatic transmissions and torque converters really like a synthetic hydraulic oil made for agricultural tractors. But your converter and transmission might hate it. I do not know anyone who has tried the API GL-6 and half quart or so extra that Jimmy Bridges suggests who slowed down, or lost a gear. I wish I had gotten around to trying it with the 5.00 gear, it might have saved a gear that appears to have been weak.
Alan Roehrich 212A G/S Last edited by Alan Roehrich; 01-15-2014 at 07:02 PM. |
#54 |
Liked 759 Times in 379 Posts
1. when I talk, it's about MY cars I don't refer to them as "our" car. So is this camaro you refer to YOUR car that YOU own and drive or not? Further, when I refer to MY cars, I don't make vague statements like "about 4-6 years and about 400-600 passes", I know exactly the duration of time and the number of runs and one would think that a claimed vastly more knowledgeable class racer would keep a log and too know EXACTLY the number of runs on every component.
2. By your lack of reference I'll take it that there is no data/field test/results from the API as well the OEM specifically as it relates to using these oils and lubricants in drag racing engines, transmissions, rears and cars! 3. 200 passes in the stock 1968 12 bolt under a 3880 lb. Chevelle that launched wheels up every pass, running as quick as 9.72 and 60 footing low 1.30s and a best of 1.28! [ame="http://www.youtube.com/watch?v=rbKYio6OvKM"]THE PROOF IS IN THE PERFORMANCE - YouTube[/ame] 3. if your replies in this thread is an example of your knowledge than without question I have more ON THE TRACK experience than you! Last edited by 1320racer; 01-16-2014 at 08:54 AM. |
#55 |
If you were half as great as you think you are, you'd be world champ in every class. But alas, you're just a world class blowhard.
Chad Rhodes 2113 I/SA |
#56 |
Does this forum have an "ignore" feature???
#57 |
I never claimed to be "great" but I am knowledgable and experienced on the topics I reply, offering 1st hand advice and opinion.
becoming a world champ has nothing to do with one's mechanical ability and/or knowledge of the mechanical components in the cars they drive! Last edited by 1320racer; 01-16-2014 at 10:23 AM. |
#58 | |
#59 | |
Liked 373 Times in 129 Posts
"becoming a world champ has nothing to do with one's mechanical ability and/or knowledge of the mechanical components in the cars they drive!" Ed Bigley More than likely it does. What about setting records? What about when the race turns heads up, something you would know nothing about. I have a question, Being your mechanical abilities run so deep, and your on track experiance and all, and twenty years of racing this 68 Chevelle above in negative 1000 feet air, how did THIS put 8 tenths on your junk in 50 passes total in 615 feet air? ![]() 1.283 3.74 5.86 115.7 9.29 142.24 Documented production oval port big block And I might add, this year I would bet it will be right there with your 522 inch SS/GT car, and faster pound for pound. Last edited by HP HUNTER; 01-16-2014 at 11:05 AM. |
#60 |
Liked 783 Times in 195 Posts
You would do well heed your admonition to me.
Your 22 years experience racing your Chevelle and your Firebird could have been well spent developing wisdom and interpersonal values rather than just an ego. Your impact on other people through relationship is far more valuable than any perceived success in the race world. Your great knowledge and experience is wasted because so few people will listen to you with any credibility. People simply don't give credence to somebody who consistently is demeaning, combative and disrespectful in their attitude toward them. And this has become the topic of this thread. |
