Liked 7 Times in 6 Posts
Any idea what size the Autolite 2 bbl carb was, and weather it's anywhere close to big enough for stock eliminator? Nhra specs are DO-OF-L auto?
Liked 101 Times in 52 Posts
Is that the 1.23 Venturi? rated 351cfm? Doesn't the guide list the 351W there with 1.73 rockers? Not correct I think. Had asked Mr Lunati many years ago at Indy about a cam for a 71 351C 2V and he said something along the lines of "kid, you can't pass enough air thru the carb to run the index."
That's what i was afraid of, good heads but a tiny carb. Ty
Liked 240 Times in 112 Posts
Tim,
I'm currently assembling a 72 240hp 351c for my cougar. My engine is required to have .407 lift @ the valve & the 1.21 carb. The 70 uses a bigger cam and the 1.23 carb. Also, a 351W & 351C are both rated @ 250hp in 70. I have it on good info, from someone who ran this before, that my combo is quite capable of running the index. ![]()
Dave Noll, EF/S ,?/SA 6526 |
Thanx for the info dave, hopefully I'll run into you, not literally, at the races. I'm in div6 as well.
Tim, Did or do you have a light colored Ranchero ?
I bracket raced a white, then later on, red 64 falcon ranchero for years. I now run an n/sa, o/sa 89 mustang.
Well then if that was you, we raced each other in a final round in 1989 the week before the bracket final's.(Renegade) You won. My car bogged so bad it almost died.
Yep, that was me. That was a crazy trip. We drove my ranchero 200 miles after work, raced, ran the finals after midnight! Then drove home 200 miles trying to stay awake. Good talkin to you Dave.
