Old 12-06-2012, 09:26 AM   #11
Rsmith38
Liked 28 Times in 15 Posts
Default Re: Help!
I had a problem with the Jeep - Tire would spin then hook RPM climbs fast then drops when it hooks. Data logger shows a big hump, then drops and starts climbing again. TACH looked as yours does.
Rsmith38 is offline   Reply With Quote
Old 12-06-2012, 09:34 AM   #12
bert powell
Liked 34 Times in 12 Posts
Default Re: Help!
Originally Posted by M&M Motorsports View Post
It looks like maybe more than one thing.
Fuel delivery is a possibility. Make sure regulator and line to carb are ahead of carb. Check float level and pressure. If you run higher pressure like 7 or 7 1/2, I would try a float setting of .425. Also make sure fuel isn't coming out of vent tube at launch. ( 90 degree spark plug boot facing forward on vent tube should take care of this)
As far as shift point , some transmissions will " lag" as much as 700 RPM. Just set accordingly.
These kind of things will give you fits. Hang in there!
Regulator is a foot forward of the carb.Run 6 1/2 psi. Float is set at .250, have ran this on numerous carbs and no issue. May want to try .425. Always use the spark plug boot. I agree it is blowing past the shift point setting. Thanks for the input and anything else you can add.
bert powell is offline   Reply With Quote
Old 12-06-2012, 09:54 AM   #13
bert powell
Default Re: Help!
Originally Posted by Barry Polley View Post
Data logger? First place I would look is battery (shorted plates), supply and grounds.
No data logger yet, starting to sound like a great investment though! Thought the same thing about batteries and changed them 10 runs ago, no change. Thanks for the reply, keep them coming.
Old 12-06-2012, 10:03 AM   #14
bert powell
Default Re: Help!
Originally Posted by chris hill View Post
can you post the incrementals of a good run and bad run?
1.42/4.05/6.28/110.11
1.35/3.96/6.19/110.02
Old 12-06-2012, 10:12 AM   #15
bert powell
Default Re: Help!
Originally Posted by pmrphil View Post
Have you tried to bypass trans cooler or change the lines? Possibly starving the trans/converter for oil? I imagine you've checked the pickup.
No trans cooler, thanks!
Old 12-06-2012, 10:24 AM   #16
bert powell
Default Re: Help!
Originally Posted by sugar1366 View Post
Looks and sounds like the stator locking up in the converter. I know you've had it back to be checked out twice, but you need to try another converter for testing purposes. I've seen this happen many times.
Eddie Bolton
Sent to ATI, Charlie said it checked out ok, he even put a new stator in the second time. I don't have a second converter, but Santa Claus is coming to town! Thanks!
