#31 | |
Liked 369 Times in 127 Posts
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
#32 |
Liked 38 Times in 17 Posts
No prob.
A lot of the special parts for these cars dry up pretty fast. I managed to get some of the mirror deletes recently, but those wouldn't be hard to make either. Some things I wonder about though. You'd think that based on the rulebook as written, it would be OK to run an 8.8" axle instead of a 9". Based on one of the other threads here, it sounds like maybe that is not the case? Then I wonder about the 12 bolt drop out in a 9" housing, is that not allowed in stock? I'm trying to get everything together to run the NA 5.0 coyote combination, and a 9" axle is just way overkill and has too much parasitic loss. |
#33 |
Liked 18 Times in 6 Posts
You can run the 8.8 if you want to. The 9-inch has a couple of advantages to it but if your looking at saving some cost your 8.8 will work after you beef it up.
2014 Cobra Jet FS/XX #3345 STK/SS Like us on http://www.facebook.com/pages/Daniel...25886327426822 |
#34 |
Other than ease of service and more gear ratio selection I can't really think of any. Plus I already have the 8.8 with 9" ends on it and good axles.
#35 |
I find it hard to believe that anyone would get bumped in tech for using a 8.8 in a 2008 + Mustang.
#36 | |
#37 | |
Liked 16,560 Times in 1,523 Posts
On its face the 352 looks to be better at 312hp vs. 330hp for the 363, but I can't tell you why it was rated at 330. I can only guess it was a consensus between NHRA and Ford Racing. I think it is still a good combo even at 330. The valve size to me is a wash because of the bigger bore, you should get better flow into the cylinders with the less shrouding. I also think it might be a better choice at the present time because there are none out there, you would be able to control future horse power increases. |
#38 |
Liked 1,104 Times in 302 Posts
Are you going to run an automatic or a stick? A 8.8 with an auto should be no issues, but I have a Jerico 4 speed in my M/S 85 Mustang, and I wish I had gone with a 9" instead of the 8.8. The selection of ratios is MUCH better with the 9", a 8.8 offers no ratios between 5.13 and 5.71. Also Pro gears are not available for the 8.8, I have broke 2 sets of 5.13 "street" gears in my 12 second Stocker. Also, in stock form, the 8.8 housing needs the axle tubes welded to the cast center, and tend to bend the tubes. Mine had to be straightened twice , but seems OK since we braced the tubes to the casting.
#39 | |
Definitely an automatic. In fact I'd say a "C-2" given the recent rule change. I know, I know, everyone says a 3 speed is faster. While I can see that when it is PG vs TH200, I think that there isn't much difference when it is PG vs C-4, as I don't think much of the C-4 with respect to both efficiency and reliability. So it should be real easy on the axle assy. The axle housing does already have the tubes welded. BTW, I have read a few places that MW had an aluminum 8.8 spool, but I sure don't see one listed. Has anyone ever actually seen one? |
#40 |
The supply of manual rack and pinions is about exhausted. No longer available through Ford, I did get one from seller rbracingford on ebay. I know Flaming River makes one too, no idea how it compares as far as weight, ratio, etc.
