Old 09-30-2012, 08:31 PM   #1
Johnny Rod
Default Help vin code
Can someone help me decode this vin # 11427WRNO59444 said it's a 1971 nova ss 350 /270 blue on blue 12 bolt Thanks. John
Johnny Rod is offline   Reply With Quote
Old 09-30-2012, 09:01 PM   #2
dartman
dartman's Avatar
Liked 68 Times in 41 Posts
Default Re: Help vin code
this may help
http://www.novaresource.org/v71.htm
1231 FS/D Drag Pak
1231 E/SA 71 Demon
Kelly MacKay
dartman is offline   Reply With Quote
Old 09-30-2012, 09:07 PM   #3
71lemans
EXAMPLE:
Your Vin doesn't look right and it can only tell you if it was a V8 or L6 car.
A 11427 is a V8 2 door sedan.
71lemans is offline   Reply With Quote
Old 09-30-2012, 09:17 PM   #4
FED 387
Liked 332 Times in 180 Posts
me thinks ya got too mwillow any or the wrong numbers here--- is this the VIN number or the cowl tag???
Anyway 114271W059444
breaks down this way
1---GM Division---- chevrolet
14--Model series----novaV8
27---Body style---2 door sedan
1--- model year ---1971
W---assembly plant----Willow Run
059444---production sequence number
do not understand the other letters/numbers you posted but that is what the number should look like
Old 10-01-2012, 03:30 AM   #5
Johnny Rod
Thank you for the info, waiting for the cowl tag #s
Old 10-01-2012, 07:53 AM   #6
Billy Nees
Liked 7,726 Times in 1,739 Posts
Hi Jonny, If you're trying to figure out if it's a real SS, I don't think that you can. I think that the best you can do is find enough of the right option #s in the car to assume that it's an SS. Got a build sheet?
Billy Nees 1188 STK, SS
Old 10-01-2012, 09:08 AM   #7
FED 387
In some cases Cowl tags have no bearing on the way the car was originally built---stamped as 4/6 cylinder and built with a V8 or vice versa--it usually is more concerned with trim/color/interior and production plant sequence other pertinant info etc---yes I know it says V8 but is it really a V8---also since 40 years has elapsed many bootleg recreations have appeared---case in point 66-67 Chevelles with 396 engines---there are probably more 396 cars running around now than GMever built---look for thr build sheet as well as warranty books previous owners etc.
Old 10-01-2012, 10:27 AM   #8
MAURICE BLENDHEIM
Liked 284 Times in 87 Posts
Johnny... If you are trying to figure out if it is a real SS car, go to the rear and see if it has a factory exhaust hanger on the drivers side. All SS cars came with factory dual exhaust and should have factory hangers or mounts spot welded in place. Another factor is any 4 barrel car has 3/8ths fuel line and all SS cars have it. The same follows for Chevelle's and Camaro's.
MAURICE BLENDHEIM is offline   Reply With Quote
Old 10-01-2012, 11:36 AM   #9
Billy Nees
2V 350 cars also had 3/8 line. You could also get a base car with dual exhaust.
Old 10-01-2012, 08:50 PM   #10
Johnny Rod
Hi Maurice, yes it has a 3/8s fuel line and the ex hangers. Has a12 bolt rear to. And yes Billy you are right .
