Old 06-19-2012, 01:42 AM   #1
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Question 402 BB Chevy Hp?
Hi guyz I just got my engine back from machine shop & I have a couple questions.. The engine is 30 over 402 plate honed & decked 10. .182 dome pistons. 106cc oval port heads Performer intake with an 800 Q-Jet . cam 224@ .050 .510 lift hyd roller. Question 1) How much power will this combo make? 2) the car is a 1967 Camaro with 350 turbo 9" 4200 converter with 4.11 gears...what E.T. ya think it will run? ( it's a street/strip car) Thanks for your input
Old 06-19-2012, 08:43 AM   #2
monte442
Liked 3 Times in 1 Post
Default Re: 402 BB Chevy Hp?
Depending on how the heads were done,I would guess somewhere in the 450 range for power.
monte442 is offline   Reply With Quote
Old 06-19-2012, 10:36 AM   #3
Considering I'm not a fan of the Performer intake (the RPM version is fine) and I don't know how well the heads are done (no mention of big valves or porting), nor whose cam it is, I'm going conservative and figuring 350-375.
That's a ton too much converter (about 1500 RPM too much), especially with that small a cam and a 4.11 gear., it will probably hurt ET, and especially MPH. In a good state of tune with traction, mid 13 seconds.
Old 06-19-2012, 12:12 PM   #4
Chris1529
Liked 70 Times in 29 Posts
This is just like Pass Time on Speed! I'm waiting for Ken Herring to chime in at any minute!
How much does it weigh?
What trans? PG, 350, or 200, 700R4?
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 06-19-2012, 12:50 PM   #5
greg fulk
greg fulk's Avatar
Red face Re: 402 BB Chevy Hp?
Alan I agree on to much converter...heads are 72 model 402 heads with stainless valve 3 angle valve job good springs...stepping back in looking @ it I was trying to save a few bucks...Comp Products has a GM "take out" hyd roller for $34...with 1.8 rockers would make it .510 lift...but if I'm going to have to buy a converter.... I was just wondering if you guys thought it would run 12's I was thinking maybe but now not so sure. Prob just keep stuff I got & buy a better cam
Old 06-19-2012, 01:56 PM   #6
Those take out cams are old Crane cams out of boat engines for the most part. They don't normally have enough RPM range for the gear and converter you have.
Consider a Lunati Voodoo camshaft, steel billet with the standard iron distributor gear (you have to order it that way) or use the regular steel core and a Comp composite distributor gear. The old number is 60212. The new number is 20110712. You could go one step bigger with the 20110713, but you don't really have the compression or the intake (you need an RPM series or similar to make it work right).
With that converter, you could run a Comp 11-456-9 (the -9 makes it steel, and a custom), they say it is for a boat, but if you put it in at 108, it has a real broad power band. It does not have as much lift as the Lunati. I run the Comp steel cores with their composite distributor gear, they work great.
Old 06-19-2012, 08:08 PM   #7
Tim H
Tim H's Avatar
Liked 484 Times in 160 Posts
I think it will run 12's ...
Old 06-19-2012, 09:31 PM   #8
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
Your combo is similar to my stocker combo, but you have 1 point more comp. and.100 more lift. I would try the conv. you have, it should be close, it might be a little loose for the street.I would say high 12's gsa612
