Old 01-10-2012, 01:29 PM   #1
CH.CRAFT
Location: PORT ALLEN, LA. NEXT DOOR TO STATE CAPITOL RACEWAY
Default Goodyear date code ?
Anyone know how to read the date code ? I called the south central distributor, they couldn't tell me and gave me a ph. Number to a engineer and am waiting for him to call me back. The code is "5ZVH"
CH.CRAFT is offline   Reply With Quote
Old 01-10-2012, 02:14 PM   #2
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Default Re: Goodyear date code ?
I might be wrong but on DOT tires the date code is four numbers,as in, 2810,which would be the 28th week of 2010.Check on both sides of the tire and see if you find one with four numbers.If not then in the immortal words of Emily Latella "never mind".
Former NHRA #1945
Former IHRA #1945
T/SA
Old 01-10-2012, 02:26 PM   #3
CH.CRAFT
It appears that gy has changed from old system, ie the "2810" as you stated. There is no other four digit codes on either side.
Old 01-10-2012, 03:50 PM   #4
FED 387
Liked 335 Times in 182 Posts
Exclamation Re: Goodyear date code ?
you will need to know the D code number on the tire, the size, and that number letter code when you talk to Gyear---they no longer use a date code like years past---the new way of coding tires has the "code" you found and will tell you the number of tires produced in that batch,the date of manufacture, construction and compound characteristics of that batch of tires etc---YOU CAN NO LONGER TELL THE PRODUCTION DATE OF A G'YEAR RACE TIRE by a date code as in years past they went away from that more than 2 years ago---make sure you have that info handy when you talk to the Gyear race tire guy---that is the only way to tell any dates etc
Old 01-10-2012, 06:11 PM   #5
CH.CRAFT
Originally Posted by fed 387 View Post
you will need to know the d code number on the tire, the size, and that number letter code when you talk to gyear---they no longer use a date code like years past---the new way of coding tires has the "code" you found and will tell you the number of tires produced in that batch,the date of manufacture, construction and compound characteristics of that batch of tires etc---you can no longer tell the production date of a g'year race tire by a date code as in years past they went away from that more than 2 years ago---make sure you have that info handy when you talk to the gyear race tire guy---that is the only way to tell any dates etc
you are exactly right ! Carter-maxwell said they did not know how to read the code and gave me the number to an engineer, (chad), who retuned my call and stated that you can not read the new code. He further stated that "they stopped the old numerical codes to stop teams from picking through tires to get the newest dated tires". He told me that my slicks were made "in the middle of april 2011". Super secret squirrel crap !
Old 01-10-2012, 07:51 PM   #6
FED 387
Call Competion west in Michigan their guys "seem" to be a little more knowledgeable when it comes to the "sportsman" tires--not saying that your guy is not but its worth a call- FED387
Old 01-10-2012, 08:13 PM   #7
CH.CRAFT
call competion west in michigan their guys "seem" to be a little more knowledgeable when it comes to the "sportsman" tires--not saying that your guy is not but its worth a call- fed387
i will contact them, thanks.
