Old 12-23-2010, 05:26 PM   #1
sox
Liked 13 Times in 8 Posts
Default Air Cleaner Question
Can anyone tell me what kind of Air Cleaner the Stock Guys run.I just bought a 75 Nova Stocker.I will be asking a lot of questions about the Car,so be easy on me..Im new to the Stock Class.Im not sure the guy I bought it from was up on latest in tech. Thanks...
sox is offline   Reply With Quote
Old 12-23-2010, 05:37 PM   #2
Jim Kaekel
Liked 535 Times in 110 Posts
Default Re: Air Cleaner Question
On a car with a factory flat hood, most use something like a large dia. Moroso or one of the high flow, spun aluminum models that are prevalent in roundy-round racing. If a heads-up race comes up, off comes the top and element, leaving just the base in place. My .02.
Jim Kaekel 3836 STK
Old 12-23-2010, 06:06 PM   #3
sox
I thought I had to run the factory Air Cleaner but a aftermarket Filter.
Old 12-23-2010, 06:47 PM   #4
Jeff Lee
Jeff Lee's Avatar
NHRA does not allow those and they have apparently been cracking down on them. Why I don't know, but thats what has been reported (even in SS they have said no).
You can run a factory canister with or without the lid or nothing at all. You can run the "standard" aftermarket Moroso style. If you had a ram-air system you have to run the OEM components to get the air from here-to-there.
Jeff Lee 7494 D/S '70 AMX
Old 12-23-2010, 09:27 PM   #5
Bill Belden
Bill Belden's Avatar
Sox, you have a pm
Bill Belden
Retired Stock Eliminator
[emailSTK1100@comcast.net[/email]
Bill Belden is offline   Reply With Quote
Old 09-29-2011, 02:17 AM   #6
JP
JP's Avatar
You can cut them but not weld or glue...
Originally Posted by stk4178 View Post
I know this an older thread, but I have a question about the EFI air cleaner setup. What can be done on them?
JP is offline   Reply With Quote
Old 09-30-2011, 01:59 PM   #7
James Perrone
Liked 1,855 Times in 433 Posts
You can use the spun circle track air cleaner..
You are not allowed the spacers provided with the air cleaner..
Tech man has to be able to put a straight edge across the top of air cleaner and be able To touch carb air horn ..
james perrone 1290 STK
Old 09-30-2011, 02:23 PM   #8
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Thumbs up Re: Air Cleaner Question
I believe Dusty runs the spun circle track air cleaner James is talking about here, or am I wrong? Jim
Old 09-30-2011, 06:17 PM   #9
Doug Blackley
Doug Blackley's Avatar
When did that change?
Doug Blackley 1697 STK
Old 10-01-2011, 02:23 PM   #10
James Perrone
Wink Re: Air Cleaner Question
Its all good been running it for quite a while
Micheal had a problem at Chicago Nat last year
Got to Englishtown next race they made a ruling on it
