Old 11-19-2010, 10:37 AM   #21
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
Default Re: Why No Protest?
Buy known quality parts and have them frozen and coated helps.
That would be "REM & Cryo". Call Jim Bailey at FINISHED... finishedracing.com Pretty cheap insurance!
Old 11-19-2010, 10:39 AM   #22
Bobby Zlatkin
Bobby Zlatkin's Avatar
I've been under the impression that you can eliminate the damper on applications that originally can with them. Am I wrong about that?
Bobby & Norene Zlatkin L/SA
Bobby Zlatkin is offline   Reply With Quote
Old 11-19-2010, 10:51 AM   #23
Liked 1,821 Times in 413 Posts
Before the new rule, you could be DQ'd for removing the damper, as the rule required the valve spring to be the same configuration as that listed in the blueprint specifications. So if you had an engine that required a 1.55" dual spring with damper, and you took the damper out, the spring configuration no longer matched the the blueprint specification. A tech man that was so inclined could DQ you.
Old 11-19-2010, 11:21 AM   #24
Bobby Zlatkin
Thanks Alan, but I guess it's a moot point now.
Old 11-22-2010, 01:11 PM   #25
Jack McCarthy
Liked 476 Times in 117 Posts
little easier for me, unfortunatley i (woody) just redid my heads...
but now can get rid of pile of shims and get behive springs...
wont make any HP difference, my SMALL CARB & INTAKE are my RPM limiter not the springs
jack
and no they wont let me run the cheater 459 intake ?
Jack McCarthy 3609 STK
"the Captain"
Jack McCarthy is online now   Reply With Quote
